CF-30 Battery info
Discussion in 'Panasonic' started by whiteley91, Oct 24, 2017.
  1. whiteley91
    whiteley91 Newbie
    Just wondering if anyone has any idea on how to set up the batteries on windows 7 so it would use the main battery first and then the media battery? It would be handy to deplete the main battery first and yank it out to install a new main battery while the media battery takes over for awhile. thanks
  2. Shawn
    Pretty sure that is controlled by the bios.
    A bios edit and reflash would be needed.
    toughasnails likes this.
  3. Toughbook
    Yup... Controlled by the BIOS... Edit at your own risk.
    (But I get your drift!)
  4. toughasnails
    This is something that I could not figure out why Panasonic never did this is the first place.
  5. whiteley91
    whiteley91 Newbie
    I was hoping it was just a hidden menu item i didn't find. Would make a great feature being able to hot swap in another main battery without a power down. I wont be going near the BIOS anyway! Thanks for the info though guys
  6. Shawn
    If I recall, the 31 will run on the media battery alone while you swap main batteries.
