CF-27 DVD drive issues
Discussion in 'Panasonic' started by Roger Mialkowski, Dec 29, 2017.
  1. Roger Mialkowski
    Roger Mialkowski Notebook Enthusiast
    Yes, if you can test a DVD drive on your CF-27, that may give me some peace of mind.
    I can't remember if I had to configure it as Force USB 1.1 in Plop when I am booting a stick from the onboard USB port. But I didn't select that with the PCMCIA USB 2.0 controllers. I have an Adaptec AUA-1420A and a D-Link DUB-C2.
    I had checked out antiX17 but after I think the screen went dim after I dumbed down the display to 800x600. I have tried 16.3 and it worked correctly with 800x600 at bootup.
  2. SHEEPMAN!
    SHEEPMAN! Freelance
    I thought I had an answer but....my 27 won't read DVD either. Arch attempted to load but turned out to be a CD. :(
    Point of interest is that my DVD shows up as Master in bios. Hmmmmmm.................thinking.
    I haven"t read Shawn's links yet.
    More after dinner.
  3. SHEEPMAN!
    SHEEPMAN! Freelance
  4. Roger Mialkowski
    I think he's referring to if you want to watch DVD movies, that's what the decoder would be for. I just want to boot from DVD like I do with CDs. Strange that the BIOS says it recognizes the DVD/CD-RW drive and that you can enable the option in BIOS setup to even boot from CD/DVD. The DVD drive light flashes and flashes with a DVD inserted and then comes to a stop after 30 or more seconds. CDs take only a few seconds to be seen. I've even tried an original just-opened out of the package Windows 7 Home 32-bit DVD to see if if would recognize, not necessarily boot to the Windows Setup, just stop flashing after a few seconds once it catches the track or whatever it does to recognize media.
  5. Toughbook
    Did you solder the jumper to make it a master? In my experience... When you swap out the old CD for the DVD you needed to solder a jumper to force it as master.
  6. Roger Mialkowski
    I shouldn't have to since I bought the DVD/CD-RW model for CF-27/28/29, right? Unless both sellers swapped the original contents out for other DVD drives.
  7. Toughbook
    I could swear those were all CD Roms back in the day... Which is why there was such a movement out there to swap over the DVDs. Only a handful of the DVD were coded as master and would work right out of the box. I always soldered the back of the PC board to force it to master. I wrote a tutorial on that in 2007 I think. It is somewhere around here.
    toughasnails and Shawn like this.
  8. Roger Mialkowski
    What about CF-VDR282U and CF-VDR291U, those are supposedly DVD-ROM/CD-RW drives from Panasonic that are for the MP TB's. I've tried 2 of the 291U's but neither are reading DVD-R, DVD+RW, DVD+R or even a brand new just opened Microsoft Windows 7 DVD. Is the 282 a more compatible drive for the CF-27 or should either work?
  9. SHEEPMAN!
    SHEEPMAN! Freelance
    I stumbled on an original faceplate (all black) CF-VDR282u.
    Windows 7 bootable DVD attempted to run and quit on insufficient ram.
    Mint 17.2 attempted to boot but quit on error partway through. (settings were forcepae nomodeset) Again I think it was too much for the tiny bit of ram.
    If I find another one I'll try it too, but PANASONIC DRIVE PACK DVD-ROM & CDR/RW DRIVE PACK seems to work.
    IOW mine would use the DVD but I have insufficient ram for the DVDs I found so far. IMGA0173.jpg
    Shawn likes this.
  10. Roger Mialkowski
    No worries that the DVD didn't start the setups, it's that they were at least reading and processing the data on the DVDs whereas the two DVD drives (291U) I tried were not. I'll probably start looking for a 282U since I have your findings. Thanks so much to all for taking the time to look into this!
