CF-19R and LTE4G (Verizon) Modem - MC7750
Discussion in 'Panasonic' started by dinda156, Mar 17, 2014.
  1. dinda156
    dinda156 Notebook Enthusiast
    Hello!
    I have (2) brand new Sierra Wireless MC7750 LTE 4G modems (Verizon network) that Heartland just shipped over to me.
    I have (2) CF-19RHRAX1M Toughbooks that I installed these modems to. I hooked up the antennas. There is no dip switches. These are GOBI 4000 modems. I have visited the Carrier Software page over at Panasonic and installed the following files:
    MC7750_VZAccess_Manager_7-7-1-12-2763b.zip [zip, 27mb]
    MC7750_QMIDriverPackage_Build3644_Win7.zip [zip, 30mb]
    MC7750_03.05.10.9.zip [zip, 21mb]
    The OS is Windows 7 Pro 32 bit. All MS updates and all the Panasonic drivers are already installed.
    The only thing I can think to try is to re-install the wireless switch utility.
    Any thoughts or suggestions? I have an e-mail into Heartland as well (gag).
    Thanks!!
  2. dinda156
  3. Alecgold
    Alecgold Notebook Evangelist
    You used a bios tool? Is there a optional tool kit menu in your bios? If so you should see the WWAN there and set the value to the right com-port number.
    I did upgrade my mk5 to a Gobi 5000, but as I had a Sony Ericsson before, I just uninstalled all the software and installed the Panasonic/Sierra software. Didn't go without a hitch, but it's working pretty decent now.
  4. Rob
    Rob Toughbook Aficionado
    Keep in mind that the MK4's TECHNICALLY don't work with the 4G LTE chips. Although, having owned one it works, BUT, BUT - they do NOT work if your computer ever goes to sleep. They never resume correctly and you'll have to reboot the whole computer. I tested this theory at the time with an MC7725 (ATT 4G LTE chip).
    Thanks!
  5. canuckcam
    canuckcam Notebook Evangelist
    FWIW, the MC7700 works just fine in my CF-19 mk3 ... sometimes the watcher doesn't display the connection properly (freezes at "connecting..." but connectivity is fine)
    I also have a Novatel e371 that I've never gotten to work properly but it's even harder to find proper software for Novatel than for Sierra Wireless. No idea why there's so much proprietary-ness (specific watcher for specific card for specific carrier) and secrecy ("we don't support x, contact your distributor for more info")
    snafu168 likes this.
  6. dinda156
    I hear ya Rob. Fortunately this has not been a problem for my department (Urban EMS System), as we do not allow the Toughbook to go to sleep since it's usually in a mobile docking station or connected AC power brick.
    It's odd, because Heartland gave me the part number and informed me it was "compatible" with the CF-19R's.
    My next project which I'll probably write up in a separate thread is to get the Lenovo Gobi 4000 (MC7750) modem to work in the CF-19R. So far I have 1 out of 4 of the drivers loading correctly. Work in progress trying to document a process for others to use.
    Thank you all for the collaboration.
  7. dinda156
    No option in the BIOS that I could locate.
  8. snafu168
    snafu168 Notebook Enthusiast
    Canuckcam,
    I'm having some issues getting the driver to install for my MC7700.
    I don't know if I messed up on the dip switch settings or what.
    Can you offer any pointers?
    I'm also on a mk3 CF-19 running windows 7 Ultimate 64-bit.
    Thanks in advance!
  9. Alecgold
    What is the error you get? The software won't install? Or the installed software isn't working properly?
  10. snafu168
    I was just getting a "Driver install failed"
    I was able to resolve it when I stopped being lazy and went in and manually installed the driver the long way Through the "browse my computer" then "let me pick."
    Doing the "search for driver software in this location" method didn't work and frustrated me for a little while.
    Just got my SIM and going to try it out as soon as I get a chance. I'll update after that.
