CF-19K mk3 Gobi Install Problem
Discussion in 'Panasonic' started by trednie, Jun 2, 2011.
  1. trednie
    trednie Newbie
    I see many threads that talk about installing Gobi modems into the toughbooks, and the steps to take, like dip switch settings, etc. I have followed as many of those as I can find and still no luck.
    My card is recognized as the Qualcomm HD-USB in device manager. WWAN is enabled in BIOS. I've tried the different settings with a battery pull, powerswitch for 30 seconds prior to powering on. When I attempt to install the drivers, the Panasonic CSA states no GOBI device found. I've tried other GOBI drivers, and actually got 1 set to install, but no luck with creating a modem device. I have gotten to the point of having a QDLoader Com Port there, but can't get any further. Maybe some else has had luck with this. I purchased it with it stating it was for the CF-19, and I have seen pictures of it in a Toughbook, with the claim it works. I have attached the pictures of the card to aid in it's identification. It states on the modem it is a J9CUNDP-1.
    I have also attached the pictures of the dip switch settings, and guide. Can anyone help???
  2. rusty503
    rusty503 Notebook Evangelist
    What OS you running?
  3. trednie
    trednie Newbie
    XP Pro with SP2. Will want to eventually migrate to Windows 7 but waiting for a critical piece of software to support it.
  4. Pinecone
    Pinecone Notebook Consultant
    Which country are you in?
  5. db04p71
    db04p71 Notebook Deity
    Two things I can think of. First, the dip switch settings for WWAN1 should be the correct one. That is what a CF-19 Mk2 uses with Gobi. Second, make sure you have the latest version of the CSA, version 2.00.1100.01.0193 is the one I currently use. Version 1 will not work with Windows 7 plus there are added benefits of version 2. At the moment, I can't verify the Gobi card. Maybe I can later tonight or tomorrow.
  6. trednie
    trednie Newbie
    I Definitely have the most recent csa package. Dip switches set per wwan1 was tried, shows in device manager as qualcomm hd-usb device but csa says no gobi device found. Running the manual install of the verizon package installs a port called qdloader, but no other device,and doesn't appear to load the modem firmware.
    If it helps I'm in Canada. I also Have a cf19 mk4 with gobi that was factory installed and use the csa to install the at&t connection manager. Once I tell it is ok to use a non at&t sim works very well.
  7. tango_tough
    tango_tough Notebook Guru
    Where did you get the gobi card, make sure it is a white list card from panasonic !
  8. kb9kst
    kb9kst Notebook Geek
    UNDP-1 should be WWAN3 for the dip switch selection.
    WWAN1 is EVDO, WWAN2 is HSDP A.
    Jason
  9. canuckcam
    canuckcam Notebook Evangelist
    If you got the card from eBay, most likely it's a locked to HP or Lenovo. Most sellers say "unlocked" but that just means it's unlocked to carriers/networks, not BIOSes.
  10. db04p71
    You may be right. I was going to say WWAN3 until I compared the switch setting to a Mk2. On a Mk2 UNDP1 is 1,on, 2,on, 3,off, 4,off which is the same as WWAN1 on a Mk3. Of course, Panasonic could have completely changed things between Mk's. Regardless, one of the settings should work.
    I just compared trednie's Gobi card to mine. The IC and FCC ID are the same however, my card does not look like that. One thing different is that my card says UNDP-1 and Qualcomm on the label with the FCC ID. You may check the number on the back of the card. Mine says T77Z039.02 LF, Rev. 02L3.
