CF-19 wwan switch settings
Discussion in 'Panasonic' started by Liteace, Aug 15, 2012.
  1. Liteace
    Liteace Notebook Consultant
    Hi, I have just pulled a EU860D wwan card from a MK2, it was working and was shown in the bios, Ive just stuck it in a Mk3, anyone know what the switch setting are, ive tried a few but cant get it to show in the bios
    Thanks
  2. BaRRmaley
    BaRRmaley Notebook Deity
    It's not a switch problem I guess.
  3. Liteace
    Any idea what could be the problem then ?
    Thanks
  4. db04p71
    db04p71 Notebook Deity
    Probably that the EU860D wasn't available in a Mk3. Panasonic switched to the Gobi2000, IIRC, on the Mk3. There is a diagram of switch positions on the board with the switches. Try those three combinations. If none work you're out of luck, IMO.:(
  5. Liteace
    I removed it, re-installed it, set the switches to wwan 1 and its now showing in the bios, maybe it wasnt seated properly, Ive now just got to find some drivers for it
    Thanks
  6. onirakkiss
    onirakkiss Notebook Deity
    had u pulled the battery out and removed the power plug?
  7. orange_george
    orange_george Notebook Evangelist
  8. Rob
    Rob Toughbook Aficionado
  9. Liteace
    Hi All, My Mk3 is nearly ready for work, I 1st loaded XP on it and gave it a try I have now loaded Win 7 on it (only 32-bit) all is working appart from the HDPDA modem, its listed in the device manager
    but I dont have any software, when I try and load Mobilink2.2.30.zip or Mobilink_v2.02.40.017.zip from this site:
    Panasonic Mobile Computer Wireless Carrier Software
    the install gets to about 75% and then rolls back then I get this message:
    Any idea's as what to try next ?
    Thanks
  10. db04p71
