CF-19 mk8 no lights no power on
Discussion in 'Panasonic' started by LeonSK, Mar 23, 2021.
  1. LeonSK
    LeonSK Newbie
    Hello! I bought myself cf-19 mk8 0 hours.
    Toughbook shut down randomly when in bios. No lights nothing. Tried everything cmos battery out no battery no charger removed everything from machine nothing helps. I have working mk6 with me took front button plate wirh ribbon tested on mk6 and works. With multimeter i got 0V into power button, mk6 i had 3.3V. all fuses on board are okay. Voltage is 16.06 from charger freerun and 15.87 when connected to main board.
    Can somebody help me with schematics, guide me somehow how to fix this or where to look please.
  2. Shawn
    I don't have any schematics for anything that new.
    First thing I would check the the port that the charger plugs into.
  3. LeonSK
    LeonSK Newbie
    Maybe somebody can find mk6 schematics. Power reaches most biggest mosfets. I located I/O chip yesterday gonna test that today i think problem is there.
  4. LeonSK
    LeonSK Newbie
    I compared biggest stuff with working mk6 unit easy stuff is not problem. Main board electronics is problem. Mk6 seems mostly same inside.
  5. BaRRmaley
    BaRRmaley Notebook Deity
    Ok :) Test mk8 with mk6's charged battery and whether mk8's battery is charged. Easy stuff to check before disassembly :))
    Shawn likes this.
  6. LeonSK
    LeonSK Newbie
    Tried this also :) nothing helped i think some mosfet is dead.
  7. Shawn
    Can you just return it to the seller?
  8. LeonSK
    LeonSK Newbie
    Nope i bought it this way. Seller sayd they do not attempt any repairs so i bought it like lottery maybe easy stuff helps :D. It looks cosmetic like brand new outside also inside. If nothing helps to get mobo work ill buy tough used one from ebay and swap mobo.
  9. Toughbook
    Have you checked the RAM? Maybe swap some sticks?
  10. LeonSK
    LeonSK Newbie
    I tried everything it get no lights on everything disconnected only front buttons plate and rear VGA/COM AC vonnected. Installed them to my mk6 and they work. Ill wash mobo with IPA today maybe it helps.
    Sent from my ONEPLUS A6003 using Tapatalk
