CF-19 Mk6&MK7 Touchscreen issue
Discussion in 'Panasonic' started by gludwig81, Feb 7, 2017.
  1. BaRRmaley
    BaRRmaley Notebook Deity
    So what's a problem? Just add shortcut to your startup folder.
    Something like this
    C:\devcon64\devcon.exe restart *VID_XXXX&PID_XXXX*
    And your device will be disabled and enabled again.
    It's my way to fix gobi modems which sometimes don't want to wake up after sleep mode :)
    You can also bind this action to one of your tablet buttons (Enter, for example).
    Do you have sysadmin vacancy? :)
  2. gludwig81
    gludwig81 Notebook Enthusiast
    The problem is the script does not work... it worked a few times and does not resolve the issue.
    Something is turning this touchscreen off.. then after a few days it starts working. We will hotswap the device from the field and re image it, works fine until it goes back out into the field for a week, month, many months.
    I worked wit Microsoft and ran procmon... nothing came out of it.
    My head is almost flat from running into a wall here... :)
