CF-19 Mk6&MK7 Touchscreen issue
Discussion in 'Panasonic' started by gludwig81, Feb 7, 2017.
  1. CWB32
    that is narrowing it down a bit .
    i did not see this mentioned ... first cup of coffee ...
    have you checked for an updated bios version ?
    (i would hazard you have)
    by "log in" , i take it you mean logging onto/into the machine and not a *company* program ...
    have you tried eliminating the "log on screen" (ie : fire up the comp and it takes you right to the desktop) .
    this is also true for the "lock lout" of the machine after a certain period of inactivity ... turn this function off .
  2. gludwig81
    gludwig81 Notebook Enthusiast
    All the laptops have our custom image so it authenticates to a log in screen.
    As for the bios... we have updated to the newest and greatest - same issue :(
  3. BaRRmaley
    BaRRmaley Notebook Deity
    Try to uncheck this "Allow to turn off box".
    If you can't do that - try to fix it in registry
    http://www.thewindowsclub.com/allow-computer-turn-device-save-power
    A value of 0 allows the computer to turn off power to the device. A value of 24 (decimal, not hex) disables the computer's ability to control the device's power.
    Can't add image, trying...
    Shawn likes this.
  4. BaRRmaley
  5. gludwig81
    These boxes are both unchecked.. sorry if i said different in the adove string.
  6. BaRRmaley
    So try to check it (on) and test :)
  7. BaRRmaley
    the first one
  8. gludwig81
    Good morning, try this test now, will update soon.
  9. gludwig81
    same issues:(
  10. BaRRmaley
    Is it possible to make one caddy+hdd with clean Windows+drivers and test that config on 1-2-3 laptops that have the problem?
