CF-19 Mk5 motherboard swapping question
Discussion in 'Panasonic' started by User32, Jan 11, 2018.
  1. User32
    User32 Notebook Evangelist
    Just bought a very cheap CF-19 Mk5, and you can guess why it was so cheap: BIOS passworded in every way possible.
    Can I just swap in a 19 Mk6 board from eBay and call it a day or do I really need a Mk5 board?
  2. toughasnails
    Sending you a PM .
  3. Shawn
    Pretty sure mk6 n later uses versapad. Motherboard swap makes the touchpad work upside down n backwards. Something else is different. Cant recall at the moment.
  4. ADOR
    ADOR Evil Mad Scientist
    Have you tested the boot order yet? How about Wifi? I got lucky on one Mk3 i got in real rough shape. Loaded the image on another unit and everything worked fine.
  5. User32
    I ended up selling it, couldn't be arsed to buy every part.
    It asked for a password all the time, even with a USB stick in it.
  6. gijoe4us
    gijoe4us Notebook Consultant
    These things happen with BIOS locked CF's. I just found a Mk III perfect unit, albeit bios locked, I found a trashed Mk Iv housing, but a perfect inside, including no locked BIOS. I gutted the trashed III, pulled all of the Iv parts and stuck them in. Added some "additions", now, a perfect, less than 5000 hours CF19 MkIV, compared to my almost 35,000 hour Mk IV.
    I would definitely look at finding the low hour, unlocked, cracked, bent, broken Mk V housing in the future and putting it into your not so bad IV, or even a locked V.
    In the V, you would only have to swap the MB....
