Cf-19 Mk2 hard drive issue
Discussion in 'Panasonic' started by Captian_Nemo, Apr 29, 2019.
  1. Captian_Nemo
    Captian_Nemo Newbie
    I recently tried to upgrade the hard drive on a cf-19 mk2 from a 80gb 5400rpm drive to a 120gb SSD.
    Booted from usb and installed linux, no errors. Wont boot. I checked the bios, bios doesn't see the new SSD. I reset bios to defaults and tried again, still wont boot, bios still doesn't see SSD.
    Booted gparted from usb and turned off the boot flag, then turned it back on. Bios now sees the SSD, go to reboot, doesn't see SSD anymore.
    Cloned the old 80gb drive (which has win xp pro and linux on it) to the SSD, complete clone, all partitions and MBR. Bios still doesn't see SSD and won't boot.
    I put the old drive back in, boots fine. SSD goes back in, wont boot.
    Anyone know what's going on? How to fix it?
    Edit: SSD is a Kingston A400 https://www.amazon.com/gp/product/B01N6JQS8C/
  2. Shawn
    Windows does not like Linux partitions. Weird stuff happens.
    Once in a while we stumble across a BIOS incompatible HDD or SSD.
    It might be that.
    Delete all partitions and write new Windows MBR on SSD.
    Boot from Win7 usb stick.
    Install JUST Win7 on SSD.
    Let Win7 installer set up partitions.
    Boot when it says to and see what happens.
    UNCNDL1 likes this.
  3. Captian_Nemo
    Captian_Nemo Newbie
    I don't have a spare copy of windows to test that with.
  4. BaRRmaley
    BaRRmaley Notebook Deity
    Looks like Kingston A400 is the one of the most incompatible SSD's. I've googled and there are too many cases.
    Shawn and UNCNDL1 like this.
  5. UNCNDL1
    UNCNDL1 Notebook Deity
    Amazon offers free tech support for 90 days....might be worth a shot.
    Maybe they will refund your $
    Sent from my CF-M34
    Shawn likes this.
  6. Captian_Nemo
    Captian_Nemo Newbie
    Thanks, I think I will refund the kingston one and buy another brand.
  7. User32
    User32 Notebook Deity
    860 Evo till the day I die!
    Get the 500GB version when on sale and take it with you if you upgrade to a newer CF-19, the caddies are interchangable from the Mk1 to the Mk8.
    toughasnails likes this.
  8. Captian_Nemo
    Captian_Nemo Newbie
    Samsung makes a fine SSD, but I'm not looking to spend that much on a computer that old. Looking at $20-$25 range. Looking at https://www.amazon.com/dp/B0722XPTL6/ Anyone have any experience with one?
  9. BaRRmaley
    Bad reliability. Look for Sandisk.
    UNCNDL1 likes this.
  10. UNCNDL1
    Sent from my CF-M34
