CF 19 mark 1 ssd
Discussion in 'Panasonic' started by alex500_lv`, May 19, 2021.
  1. alex500_lv`
    alex500_lv` Newbie
    Good day to all.
    Have problem.
    A have old mark 1. Want to swap with ssd disk.
    But when I install it SSD can't detected even in bios.
    First I tried intel ssd no working
    Now droped Kingston same problem.
    Checked on other laptop both of them working.
    Old HDD working without any issues.
    Can somebody help.
    Thanks.
  2. Shawn
    Same caddy or different for each drive?
  3. BaRRmaley
    BaRRmaley Notebook Deity
  4. safn1949
    safn1949 I'm sure I'm on the wrong planet
    You are correct, I run an SSD in a CF-30Mk1.
  5. alex500_lv`
    alex500_lv` Newbie
    Ok how I can convert to MBR if disk can't detected. In BIOS it's written that none disk installed in system.
  6. safn1949
    You need to format the disk , if you have another computer format it with rufus and create a bootable usb. Otherwise liveboot a linux usb and format to fat 32 in gparted.
    UNCNDL1 and Springfield like this.
  7. ADOR
    ADOR Evil Mad Scientist
    Also if you have another laptop that has the same processor, Intel for Intel/ AMD for AMD, start the load on it and then before the second restart put it into the Toughbook. I have had to do that to a couple of 19's that had a bios lock. Worked fine other than needing help to load the OS on it.
