CF-19 - Loss of sound from internal speakers
Discussion in 'Panasonic' started by s4biturbo, Jan 6, 2009.
  1. BaRRmaley
    BaRRmaley Notebook Deity
    It's strange that the answer is still not here.
    Just rename this file
    C:\PF\Panasonic\Hotkey Appendix\HKEYAPPV.dll
    to something like HKEYAPPV_old.dll
    and your sound (including mute control) will work forever :)
    UNCNDL1 likes this.
  2. Shawn
    Do the hotkeys still work after doing this?
    I personally almost never use the hotkeys, but they are very important to others
  3. BaRRmaley
    Of course they work :)
    And you can always rename that file back if you need it. But you will not :))
    P.S. I think you'll have to restart after renaming :)
  4. Shawn
    Stolen from the web.
    What is Hotkey Appendix?
    This applications shows the available hot keys for the device. A hot key is a combination of keys or a single key on a keyboard that, when pressed at one time, performs a task (such as starting an application, launching a web browser, etc.) more quickly than by using a mouse or stepping through a series of menu items. A hot key control is a window that enables the user to enter a combination of keystrokes to be used as a hot key.
    Hotkey Appendix is a software program developed by Panasonic. The most common release is 9.0.1000.0, with over 98% of all installations currently using this version. During setup, the program creates a startup registration point in Windows in order to automatically start when any user boots the PC. The primary executable is named hkeyapp.exe. The setup package generally installs about 3 files and is usually about 1.17 MB (1,230,776 bytes). Relative to the overall usage of users who have this installed on their PCs, most are running Windows 7 (SP1) and Windows XP. While about 61% of users of Hotkey Appendix come from Japan, it is also popular in the United States and Germany.
    Installation folder: C:\Program Files\Panasonic\Hotkey Appendix
    Uninstaller: C:\Program Files\InstallShield Installation Information\{943622A3-F5E9-464F-A025-90D02F3B8ACE}\setup.exe -runfromtemp -l0x0009 -removeonly
    Estimated size: 1.17 MB
    Language: English
    Program filesFiles installed by Hotkey Appendix
    Program executable: hkeyapp.exe
    Path: C:\Program Files\panasonic\hotkey appendix\hkeyapp.exe
    MD5: 18a7880e02a0dc52c0d568f96abdcc45
    Additional files:
    HKEYAPPV.dll - Hotkey Application
    HKAppNtf.dll - Hotkey Appendix (Hotkey Appendix Logon Notifier)
    Program behaviorsBehaviors exhibited
    Startup File (All Users Run)
    hkeyapp.exe is loaded in the all users (HKLM) registry as a startup file name 'Panasonic Hotkey Manager' which loads as C:\Program Files\Panasonic\Hotkey Appendix\HKEYAPP.EXE.
  5. BaRRmaley
    too many letters :)))
  6. gray-beard
    gray-beard Notebook Evangelist
    I had this happen to me while working on a CF-29.
    While getting ready to swap out a hard drive I used the hot keys to mute the sound.
    It must have changed some setting in an eprom to totally disable sound because I was not
    able to get sound from the unit until the hot key drivers and apps were loaded again so
    I could then enable the sound again.
    Bob
    I like ramble-on sentences :hi2:
  7. SHEEPMAN!
    SHEEPMAN! Freelance
    Quoting this because it has a cross platform application. (Windows and Linux)
    I have had a problem with a Linux program (actually two un-related problems) that were fixed by going to stand-by and return. (Close lid and re-open)
    Whether it will fix your sound I know not.......it's just interesting.
    Shawn likes this.
