CF-19 Internal Speaker issue
Discussion in 'Panasonic' started by FlameHaze, Nov 1, 2017.
  1. FlameHaze
    FlameHaze Notebook Consultant
    My internal speaker doesn''t work after a cold boot, going into S3 and coming out causes the speaker to start working, what gives?
    CF19 MK3 running 7 64bit SP1
  2. UNCNDL1
    UNCNDL1 Notebook Evangelist
    Does device manager have any flags?
    What does going into s3 mean exactly?
    Are all Panasonic drivers loaded?
    Sent from my SM-G920V using Tapatalk
    toughasnails likes this.
  3. FlameHaze
    No flags, all drivers installed, S3 sleep
    headphone jack works at all times, just not speaker on a cold boot
  4. SHEEPMAN!
    SHEEPMAN! Freelance
    S3 as in Amazon?
    Warning: sarcasm ahead...."Obviously, if you’re moving data within AWS via an EC2 instance, such as off of an EBS volume, you’re better off if your EC2 instance and S3 region correspond." What galaxy was this written in? :confused: (quote from quick google search)
    If you are saying (conjecture from above) you go on and offline and this enables sound then this is a very curious thing. o_O
    More information needed please; as in full model #, driver state, state of device manager...(any yellow flags?).
    Thanks.
  5. FlameHaze
    Hello, That is exactly what i'm saying, and it works everytime. All devices are fine.
    I don't recall the model #. Laptop is at work, where I'm currently not. It's been upgraded to add GPS, Fingerprint, Emissive backlit. Think mine is a K or L for the 6th letter(I think that the important one?)
  6. BaRRmaley
    BaRRmaley Notebook Deity
    Shawn and toughasnails like this.
  7. FlameHaze
    So basically break HKEYAPPV.dll by renaming it HKEYAPPV_old.dll or THESADBROKEN.DLL or something and it behaves again..... Everything else will be happy still from what I read. Gonna try it when I pull out the CF-19 today!
  8. FlameHaze
    File doesn't exist
  9. BaRRmaley
    Install it :)
    Shawn and UNCNDL1 like this.
  10. Toughbook
    Have you tried the Fn + F4 key?
    UNCNDL1 likes this.
