CF-19 Guide F.A.Q.
Discussion in 'Panasonic' started by ADOR, Feb 26, 2014.
  1. Shawn
    Model Number: CF-19RHRAX1M
    Status: DISCONTINUED
    MSRP: $3,629 Description: Win7, Intel Core i5-540UM 1.20GHz, vPro, 10.4" XGA Touch, 160GB, 2GB, Intel WiFi a/b/g/n, TPM, Bluetooth, Dual Pass (Upper:WWAN/Lower:WLAN), No Drive, Toughbook Preferred,
  2. LawDawgg
    LawDawgg Newbie
    Shawn, thanks for the info. I found the Panasonic optical drive you suggested. Just waiting for it to arrive..
    We'll see if that helps. If I run into road blocks I'll be back for more.
    Thanks everyone for the replies, comments, and help....
    Shawn likes this.
  3. BaRRmaley
    BaRRmaley Notebook Deity
    I think info is already in this FAQ, but I usually use the closed thread to remember dip positions and can't edit that :)
    So dip switches for UNDP-1 (Gobi 1000) in MK3 looks like this
    1,2 ON
    3,4 OFF
    WWAN1
    Shawn likes this.
  4. Kerozin
    Kerozin Notebook Enthusiast
    Shawn likes this.
  5. Karl Klammer
    Karl Klammer Notebook Consultant
    Shawn likes this.
  6. BaRRmaley
    Can't find a topic about "rotated" touchscreen, where somebody had a problem with mirrored touchscreen behavior.
    Today I've repaired one of CF-19's toushcreens (physical problem) and reinstalled drivers. After this operation touchscreen was ok in laptop mode and mirrored in tablet mode.
    How to fix that:
    1) Disable rotation in Intel graphics settings
    2) Enable rotation in Intel graphics settings
    That's all, folks :))
    toughasnails likes this.
  7. Shawn
    I just scored a CF19 mk6 for cheap..VERY CHEAP...BIOS password and all.
    I hope everything is enabled..mainly WIFI and USB 3.0
    So fairly soon I will be trying Zorin 12.1 on a mk6. Dual touch
    Then I can swap all my goodies over from the mk4. Actually a motherboard swap would be better as the mk6 case is a tad ROUGH.
  8. BaRRmaley
    You are cool, but wrong topic :))
  9. Shawn
    I was leading into how well Zorin(Linux) 12.1 works on a CF19 mk6 dual touch.
    What works and what doesn't. Sort of fits here.
    UNCNDL1 likes this.
  10. UNCNDL1
    UNCNDL1 Notebook Evangelist
    Coolio. I just ordered a MK6 to play with while in Delaware this summer.
