CF-19 Guide F.A.Q.
Discussion in 'Panasonic' started by ADOR, Feb 26, 2014.
  1. equiluxe
    equiluxe Notebook Enthusiast
    Hi I have a CF19 MK2 running windows 7 with the digitiser screen, When I installed Win.7 I found that I had to by trial and error intall some drivers from the MK2 some from MK3 and4 in order to get everything working.
    I am now considering Windows 10 as I get a free update, but the compatibility checker informs me that touch screen is not required, has anyone tried Win.10 and will the Panasonic digitiser drivers which I believe are in fact from Wacom work under Win 10.
  2. toughasnails
  3. Adrienne Peck
    Adrienne Peck Newbie
    I was recently asked to add a camera to our CF-19s. I was in contact with Panasonic and got three different answers to the same question. Bottom line is I'm now being told that retro fitting a camera to CF-19 is not possible. And then I discovered you guys!
    Question #1 - The integrated options has 'R' and 'S' as having Bluetooth and a camera. Is that the CF-19s or CF-31s? The CF-31s have an integrated webcam.
    Question #2 - The list has 'MK1' and 'MK3' - that's for CF-19s, right?
  4. toughasnails
    Welcome to the Panasonic Toughbook forum
    The down side to having a camera is you lose a memory slot . The camera is mounted on the bottom and it's no really the best. Others might be able to tell you for sure if it can be added...I am not sure. To buy these new it will be cheaper to look for one that has it already installed.
    It's for the 19.
  5. Shawn
    Not all CF31's have webcams...It is optional...
    No you can not add the camera to a CF19...It has been tried..The BIOS is different.
  6. equiluxe
    Hi dose any one have the schematics for the CF19 preferably the MK2 and 3. I have looked on the web and found the 28 and 29 ones but not the 19's
  7. Shawn
    What are you thinking about doing?
  8. toughasnails
  9. equiluxe
    Not sure yet perhaps fit a camera or some such. I have fitted extra usb ports on a couple of 28's and turned a 29 into a 20MHZ scope in the past but I am now playing arround with a 19 and a circuit schematic would make it easier to pick up any traces I need.
  10. equiluxe
    Thanks for the link, I already have the service manual but they only have a block diagram and parts list, it is the actual circuit diagram that I would really like to get hold off.
