CF-19 Guide F.A.Q.
Discussion in 'Panasonic' started by ADOR, Feb 26, 2014.
  1. rubberduck66
    rubberduck66 Newbie
    Assuming this is the right place.
    I've had my 19 now for a few days, so far it's great.
    Spec's are:
    CF 19AHC15PE mk5
    I5 2.5ghz
    120gig ssd
    4gig ram
    mobile broadband sim card slot thing (can't remember what though)
    Windows 7 pro 64 bit
    Looks like the original ac adaptor, 16volt 3.75A.
    Plans are to add another 4gig memory, a bigger ssd, GPS, emissive backlit keyboard.
  2. toughasnails
    Welcome to the Panasonic Toughbook forum
    You are in the right place. I have had my 19 MK5 for about 1 month now and love it. I have installed a GPS and aemissive backlit keyboard.in mine...works great.
  3. zombie45
    zombie45 Newbie
    my 1st post.
    cf-19 i5 mk5 2.5ghz
    power cord output 16V 5.0A
    plug that goes to wall says jet longwell ls-18 7A 125V
    bottom of laptop says DC IN 15.6V-16.0V :::: 5.0A-7.05A
    battery blue tab model cf-vzsu48 output 10.65V 5.8Wh
  4. Shuttlez
    Shuttlez Notebook Enthusiast
    CF-18mk4: CF-AA1623AA, 16V, 2,5A
    CF-19mk4: CF-AA6363A, 16V, 3,75A
    CF-19mk5: CF-AA5713A, 15,6V, 7.05A
    None of these have been purchased as new.
  5. coffey7
    coffey7 Notebook Consultant
    I just bought a CF19-RHRAX2M, 8gb ram, windows 7, what battery life should I expect? Has 1TB hard drive(non ssd)
  6. toughasnails
    You should be getting around 3 to 4 hours.
  7. Shawn
    mark4 wifi is half size card...
    full size would fit but mounting screws are in wrong location.
    Antenna covers and latch cover is different from mk3 and newer
  8. BaRRmaley
    BaRRmaley Notebook Deity
    1) MK4 SDHC reader works with 64GB SDXC card. Both read and write :)
    2) Installed 2 x 8GB RAM (16GB total) into MK5. Cool!
    3) Buy only "blue" batteries for CF-19. Other ones for sure have worse elements.
    4) CF-19 MK4 can't use USB ports in CF-VEB181, but MK5 can. Same AC adapter.
    Waiting for Samsung 850 Evo to check if MK5 supports SATA-III. Sandybridge.. has to support :)
  9. Shawn
    I found this hidden in another post.
    From Panasonic info viewer..
    Battery ID.
    the last number on the line is the date code: in my case 111006xxxxx which stands for 2011.10.06 (6th of Oct).
  10. Shawn
    Batteries for a CF 19....They seem to all be interchangeable...Except if you are using a UL1604 Haz Loc model in a Haz Loc, then you must get the CF-VZSU50..Haz Loc battery...
    CF VZSU48--Blue tab...10.65v--- 5.7Ah
    CF VZSU48U---Blue tab--10.65v--- 5.7Ah
    CF VZSU50---Green tab...Hazardous Location battery---Reported by web site as for mk1-mk4
    CF VZSU48CJS--Orange tab--Japan only ..CF-19 mk6 later??...-10.65v--5.7Ah
    CF VZSU58U..Yellow tab--11.1v---5.6Ah--For mk4 and later?-Sold with laptop only not sold separately.
    CF VZSU50W..No label info found yet..
    CF-VZSU48R.. China Only---10.65V---5.7Ah
    CF-VZSU48JS...No label info found yet..
    Info is from battery labels.....
    Interesting that some Ebay sellers are selling new in box batteries CF-VZSU48U on box, but battery says CF-VZSU48--NO U...I have seen batteries with CF-VZSU48U printed on the label..
    Myself and another member found the life span of a CF-VZSU58 is not as long as a CF-VZSU48....I think they use cheap cells in the original batteries that ship with a new laptop. Like cheapo starter cartridges in a printer.
