CF-19 Guide F.A.Q.
Discussion in 'Panasonic' started by ADOR, Feb 26, 2014.
  1. Gear6
    Gear6 Notebook Evangelist
    My 19mk4 AC adapter 3.75A 16V CF-AA6373A (M1) - different revision.
    the blue tab 48U and yellow tab 58U are the same as stated above.
  2. mklym
    mklym Notebook Evangelist
    Your AC adapter is the one your unit had when it left the factory, where as mine were bought (as replacements?).
    From the CF-19MK4 Operating Manual:
    AC adapter: CF-AA6373A with Note#1, which states 'When a replacement is necessary, purchase the commercially available CF-AA1633A AC adapter.'
  3. snafu168
    snafu168 Notebook Enthusiast
    CF-19 Battery CF-VZSU50
    Green Tab UL1604/ATEX hazardous location certified.
  4. Shawn
    cf 19 mk3 8gb ram info.
    http://forum.notebookreview.com/panasonic/636918-unusual-cf-19-a.html
    excerpt from thread
    My 2x4GB is finally here
    Elpida 4GB 2Rx8 PC2-6400S-666
    I've already installed one of them, so now I have 2GB + 4GB and it works fine under 64-bit OS.
    Will upgrade internal 2GB to second 4GB module soon, but it seems, while 4GB is not enough, 6GB is.enough.
  5. zahar1968
    zahar1968 Notebook Enthusiast
    Can I ask here?
    Yesterday Bought mk-3 CF-19KHRS51L windows7 32bit, not work WWAN
    install sim card , laptop does not see it.
    all the drivers are installed, tested Bios - enabled
    sim card from a mobile phone.
    I was told Russian SIM card may not be suitable, this is possible?
  6. mklym
    Probably would be better to start a new thread.
    Sim cards need to be inserted and removed when unit is powered down.
    No idea about Russian sim cards.
  7. toughasnails
  8. Shawn
  9. Shawn
    Just to clarify....This is the restore / recovery disk we mean...This maybe for a different model / mark, but Panasonic recovery disks only look like this.
    We don't mean a OEM disk from DELL, SONY, MICROSOFT, APPLE....etc..
  10. Shawn
    found in other posts
