CF-19 Guide F.A.Q.
Discussion in 'Panasonic' started by ADOR, Feb 26, 2014.
  1. Shawn
  2. longknives
    longknives Notebook Enthusiast
    Thank You Shawn, found and ordered.
  3. toughasnails
    Not sure which one you bought but many don't come with power cable.
  4. longknives
    I bought the one Shawn referred me too, and while searching did in fact discover that the power cable might not be included, but lady luck smiled kindly and rewarded me with the power cable as well.
    I am presently deep into trying to set up my new to me CF-19VMRFX2M w/ W10 to be benevolent & kind as well. It is a very different creature than W7
  5. Geraout
    Geraout Notebook Consultant
    Is there any consensus on the 64bit and 6gb deal?
  6. Shawn
    Do a Google search. All the speed tests I read say that you need 6gb with win7 64bit in order to acheive the same performance as win7 32bit with 4gb.
  7. BaRRmaley
    BaRRmaley Notebook Deity
    IMO, if you have modern laptop (MK4+) - use 64-bit Win. And install SSD and as much RAM as possible :)))
    If you have MK2-MK3 with 4GB RAM and plan to install more RAM in the future - use 64-bit Win.
    In any other case listen to Shawn :)))))
    P.S. I'm on mk7 now with 4gb RAM (temporarily), 64-bit Win10. And it's not slow thanks to SSD.
  8. Shuttlez
    Shuttlez Notebook Enthusiast
    Hi,
    I'm looking to upgrade a MK4 to MK6 or MK7.
    Are there any digitizer-only -versions among MK6 or MK7?
    The MK7 might, or might not, have 5-point multitouch?
    Is there a working decoder at this time.
    I'm mostly looking at eBay for units, I'll have to swap the nordic keyboard from the MK4.
    Also, what is the maximum RAM with or without camera?
    I'm also open to offers, if anyone has a unit they are willing to part from
  9. BaRRmaley
    What's a decoder in this context?
    Keyboards are compatible.
    8/16GB.
    Best upgrade is to fz-g1 ;)
    Shawn likes this.
  10. Shuttlez
    A decoded that would allow me to see with what the computer was dispatched with originally knowing it might not be accurate anymore.
    The FZ-G1 would be better for the use - possibly - but the existing vehicular dock makes a CF-19 more economical. Maybe.
