CF-19 GPS Fix
Discussion in 'Panasonic' started by MichalCallegarisr, Mar 27, 2019.
  1. MichalCallegarisr
    MichalCallegarisr Newbie
    I own a CF-19QJREX2M MK3 the Q is the designation of U.S. Air Force. This unit was original/unaltered. I added a fingerprint scanner and the original GPS unit LR95485
    After adding the Microsoft Maps and Trips 2013 and Windows 10. I could not get the Gps to function.
    here is how I got the Microsoft Map and Trips working. using my android phone connected to my CF-19 thru Bluetooth connection.
    my phone is running a small app the cost was $0.99 is called "Bluetooth GPS Output"
    www.meowsbox.com
    with the phone app running within 30 feet of the laptop I am getting 20 sat connection even indoors
    UNCNDL1 and toughasnails like this.
  2. BaRRmaley
    BaRRmaley Notebook Deity
    You are cool hacker no questions :)))
  3. Shawn
    So you are using your phones gps and not the CF19's?
    The phone sends gps data to the CF19.
    I forget exactly what settings I needed to change, but I have a stock gps in my CF 19 mk6 Win 10 running the built in mapping and navigation program. It works directly without needing my phone.
    It is called a location sensor maybe. It needs to be enabled for Win 10 to use the gps module.
  4. SHEEPMAN!
    SHEEPMAN! Freelance
  5. MichalCallegarisr
    Thanks for your help...I was just tired of making changes waiting outside for 20 then back without mine working after a couple of days I started looking for alternatives. your post is very welcomed
    SHEEPMAN! likes this.
