CF 19 battery drain
Discussion in 'Panasonic' started by Shawn, Jul 17, 2015.
  1. Shawn
    CF 19 mk4..
    ublox gps
    dual touch conversion
    intel 6300 wifi
    SSD
    fingerprint reader
    4gb ram
    custom backlit keyboard.
    Win7..32bit
    Battery has slow discharge if I leave it in the CF19. Not a full drain overnight. Probably take 3 or 4 days to drain completely..maybe longer..tried 2 different batteries. Same results..Batteries ok if left out of CF19
  2. toughasnails
    CF 19 mk5..
    OEM GPS
    dual touch
    intel 6300 wifi
    SSD
    4gb ram
    backlit keyboard.
    Win7..32bit
    Same here. Mine takes about 1 1/2 weeks . I never leave my battery in my Toughbooks
  3. Shawn
    My CF30 does not seem to have an issue with battery drain...This CF19 mk4 is definitely worse than my mk2.
  4. toughasnails
    My 30 MK2 drains in about 2 weeks "dead". Not sure about the 30 MK3 since I never keep the battery in it. I figured the 19 would be better than the 30 because it has a i5 cpu.
