CF-18 & Ledco Dock: Antenna Passthrough?
Discussion in 'Panasonic' started by Papkee, Nov 28, 2016.
  1. Papkee
    Papkee Notebook Enthusiast
    Wondering if anybody else here is using a CF-18 mk 4 with a dock and using the antenna passthroughs. I've got a CF-18 with GPS and Touchscreen (non-digitizer) and the antenna ports on my Ledco dock (model number unknown) don't seem to be working.
    I read that with some other models of toughbook you need a program that tells the laptop whether to use the internal or external antenna port. My model does have both antenna ports on the bottom dock connector and the dock has the connectors and ports on the back. However my GPS onboard is still using the internal antennas regardless of connection to the dock.
    I can't get you a model of the dock as I bought it used and the label is scratched. The CF-18 is not nearby right now but I will try and get the exact model later today.
    I'd appreciate any help or suggestions. I've successfully got Windows 7 fully working using the guide on here, so I'm hoping you guys can help me out with this issue as well.
    Cheers!
  2. Shawn
    Is it a dual or single pass thru?
  3. Papkee
    Dual passthrough.
    My apologies for being late in getting back to everyone. The CF-18's full model number is CF-18NJHZEBM.
  4. toughasnails
    This is what your 18 had when new...
    Model Number: CF-18NJHZEBM
    Status: DISCONTINUED
    MSRP: $4,774
    Description: Intel Pentium M 753 1.2GHzULV (Centrino), 10.4" Touch Screen XGA, 60GB, 512MB,Intel 802.11a+b+g, Dual pass through, WIN XP SP2,TPM1.2 GPS, Bluetooth, Backlit Keyboard, No Drive
    Dannemand likes this.
  5. Shawn
    How do you know it is still using internal antennas?
    As far as I know the pass thru on a CF18 is purely mechanical.
    If it does not work, you will need to pull the base off and trace the wires.
  6. Papkee
    The one other variable is the GPS antenna. I believe it's the type that requires power over the coax and I'm fairly certain that the dock is not supplying power to it. I may need to build a small circuit to supply it power.
    I need to do a little more testing, but it doesn't seem like the satellite reception is any different on the dock vs off the dock. That was the reason I was questioning whether the ports were switching or not.
  7. ohlip
    ohlip Toughbook Modder
    If your unit doesn't come with a label at the bottom that say upper WWAN, lower GPS. It means it is on default setup which is upper WWAN, lower WLAN. Now! you need to open up the bottom case and need to rewire but the problem is some unit has short gps antenna cable. Open it up first if it has enough lenght of cable. Then report back and I am going tell you how to rewire it.
    Shawn likes this.
  8. Papkee
    I'll probably work on opening it up this weekend. Thanks for that insight, I would've never guessed that the ports wouldn't be correct.
  9. Papkee
    Apologies for the large images. My antenna port connector has four u.fl connectors. Three of them are currently connected. The GPS module has two cables, one goes to the antenna on the side of the laptop and the blue one dissapears somewhere. The lower gray antenna comes out from around the same area the blue cable goes.
    Let me know what you can gather from this or if you need more pictures!
    Shawn likes this.
  10. SHEEPMAN!
    SHEEPMAN! Freelance
    Gray and blue are going to the lid. I think maybe the left side cover area. Pull that cover and more becomes clear. Blue is bluetooth in this case....not always.
    You need a short jumper from GPS to pass-through.....wait for Teo to tell you what goes where. :D
