CF-07 Model Numbers
Discussion in 'Panasonic' started by dans87, Jun 8, 2018.
  1. dans87
    dans87 Newbie
    Hello All
    Seams as tho a seller on ebay is liquidating the stock of CF-07's, so uh I got 18 of them
    looking though I have various model numbers
    CF-07LZ5ZYDM
    CF-07LZ5ZYEM
    looking at the service manual it seams that the model numbers break down into the following
    Model No. CF-07 1 Z 2 Z Y 3 4
    1: CPU type
    L: for Intel® Mobile Pentium® III Processor 300 MHz
    2: HDD type / RAM size
    5: 5GB / 128 MB
    A: 10GB / 128 MB ??
    C:20GB / 128 MB ??
    3: Operation System
    E: Microsoft ® Windows® 98
    D: Microsoft ® Windows® 2000
    K: Microsoft Windows XP ??
    4 :
    M: USA
    Can someone chime in with the specs & model number of thiers to see if my additions (in red) are correct?
    CF-07LZ5ZYEM - Base OS Windows 98 SE , 5GB HDD
    CF-07LZ5ZYDM - Base OS Windows 2000 SP2 , 5 GB HDD
    CF-07LZAZYDM - Base OS Windows 2000 SP2 , 10 GB HDD
    CF-07LZCZYDM - Base OS Windows 2000 SP2 , 20 GB HDD
    regards
    Dan
  2. safn1949
    safn1949 I'm sure I'm on the wrong planet
    I have to ask, what are you going to do with 18 of them? I had a few and for the life of me, I could never get the CF-08 to connect to them. Operator error I'm sure.....:D
    I bet Ador knows.
    Shawn likes this.
  3. dans87
    dans87 Newbie
    if im honest im not really too sure , kinda an impulse buy really
    Ive got the vdw07 connecting to mine
    seams as though there is very little information about the cf-07 online , only found a few topics here and some manuals on the Panasonic.ca website
    Edit :
    Known Serial Numbers
    2DKYAxxxxx
    1LKSAxxxxx
    4BKSAxxxxx
    3AYAAxxxxx
    1KKSAxxxxx
    4CKSAxxxxx
    2AKSAxxxxx
    Where x is a number from 1-9
    Known BIOS versions
    1.10L18
    1.10L14A
    1.20L10
    1.10L17
    1.10L15
    Ram Capacity
    128 MB (onboard memory only)
    192 MB (on board + 64mb stick in slot)
    256 MB (on Board + 128mb stick in slot)
  4. theoak2
    theoak2 Notebook Evangelist
    Shawn likes this.
  5. dans87
    dans87 Newbie
    interesting that the advertisement for them cf-07 states an optional gps , I hope I can find some more info on that
  6. ADOR
    ADOR Evil Mad Scientist
    I still have 3 CF-07 units. One is in a after market dock hooked to a remote screen and keyboard. I have another in the factory dock hooked to another keyboard and 02 remote screen. The third is in the factory dock and has a PCMCIA gps in it. I have it set up for the remote wireless screen. They make good car computers. Batteries that work good are hard to find.
    The cpu is a 600 mhz unit underclocked at the factory to 300 mhz to keep it cool with no fan.
    http://forum.notebookreview.com/threads/cf-07-usb-alt-adapter.545558/
    This thread shows the cable you need to add a cable for usb plug in with out a dock on the 07.
    Lots of old threads here and a should be a few at TBT
    The wikispace link won't work in the above thread, that site was shut down and deleted.
    But the web archives has some of it.
    https://web.archive.org/web/20140923030543/http://toughbook.wikispaces.com/CF-07
    http://www.pencomputing.com/frames/panasonic_07.html
    I will see if I got time to blow the dust off and take a few pictures if you need it.
    safn1949 and Shawn like this.
  7. dans87
    dans87 Newbie
    ive got 3 and two seam to hold charge for about an hour and 30 mins each , the other one lasts about 20 mins
    yeah saw that thread and bought a few cables with gender changers to adapt the end working great
    forgive me but what is TBT ?
    Even if its just model & original specs would be a great help
  8. Shawn
    toughbooktalk dot com
  9. ADOR
  10. ADOR
    toughasnails likes this.
