CD/DVD drives vs aux batteries for CF-31's
Discussion in 'Panasonic' started by sunrk, Dec 27, 2018.
  1. sunrk
    sunrk Notebook Evangelist
    Checking Ebay, I find there are at least two different models of CD/DVD drive module for CF-31's. Mine has an empty bay. I don't really think an aux battery module there is particularly useful (how good is the battery management for the Panasonic genuine aux battery unit?).
    So, CF-VDM311U and CF-VDM312U are the product codes I'm seeing.
    Anyway I know a lot of you have had CF-31's much longer than me so what do you folks find is the most practical use for the MP bay? Aux battery, or a CD/DVD drive?
    Craig.
  2. Shawn
    I have both. Also a DVD caddy that I pulled the DVD and put in a Blu-ray drive.
  3. Kardan
    Kardan Notebook Evangelist
    Hi Shawn,
    Which Blu-Ray do you recommend? I have a CF-31 mk4 performance model and an extra VDM112 DVD.
    Thanks.
  4. Shawn
    I will look and see what I put in mine.
  5. Kardan
    Not to pressure ... but have you had a chance to look up a particular make/model?
    Thanks
  6. Shawn
    I forgot.
    For my CF 52 I have
    BluRay burner..model number BT30N
    For my CF 31 I seem to have 2
    BluRay burner..model number BT20N
    BluRay ROM..model number BC-5500H
    UNCNDL1 likes this.
  7. Kardan
    Thanks!
