CCC LED Hotkey MOD for P870xMx (and possibly other models too)
Discussion in 'Sager and Clevo' started by j95, Nov 13, 2017.
  1. j95
    j95 Notebook Deity
    So, I found a solution for Clevo's bloated CC (all processes/services) and still be able to change LEDs on both keyboard & lid. Meaning, no custom fan profiles, just “Auto” or “Manual” fan control (FN+1), including CC overclocking, the latter is a terrible idea anyway.
    1) For starters, uninstall current CCC -> reboot.
    2) Download Control_Center_v5.0001.1.88.7z & Hotkey.7z.
    3) Install CCC v5.0001.1.88, then reboot when prompted.
    4) Open CCC, set "Performance" mode and fans to "Auto".
    Open Flexikey, set custom colors, first lid and then keyboard, hitting "save" each time.
    Exit CCC.
    5) Copy Hotkey folder to the root of C:\ drive.
    6) Run hotkey_settings.bat as admin.
    7) Open task scheduler. Import included Hotkey.xml task. (FCU/RS3 12 seconds 'delayed start' or manually set 15-20 sec depending on resource load).
    8) Pin GameFeet_start.exe shortcut to the taskbar and/or start menu to change colors anytime (delayed start).
    9) Perform a BIOS reset to clear CCC's fan settings. Otherwise, fans will be stuck at 80% (FN+1).
    Ruling out common issues: #1, #2
    I disabled LED 'breathing' lid effect by choosing black instead.
    PW: j95
    Code:
    Checksum information
    CRC32: 341B5D2D
    CRC64: AA1BE95E061B1C8D
    SHA256: 82079F34E79D52405892B9D1D95113A6AC50D11BBB4BAE24E0C73F4EDC2B61FA
    SHA1: 49A84227FFD0E70850647BF9E0DFC0D745F0A219
    https://www.virustotal.com/#/file/82079f34e79d52405892b9d1d95113a6ac50d11bbb4bae24e0c73f4edc2b61fa/detection
    CRC32: 6215B7BF
    CRC64: 3EF876B118F022BD
    SHA256: 9DD641F9833272D414F38BE2A7AE0356CE6C10E610FFEBFD7CA98A2AF09DFB39
    SHA1: 3ADB472E53F26B280C39528B727371FDA7C9821D
    https://www.virustotal.com/#/file/9dd641f9833272d414f38be2a7ae0356ce6c10e610ffebfd7ca98a2af09dfb39/detection
    Thanks to @Mr. Fox and @Papusan for patiently testing...
  2. Mr. Fox
    It works perfectly. Thank you for the effort you put into it. Great mod, especially for those who do not have @Prema EC mods (default white keyboard lighting and static lid LEDs) and have to look at the tacky bright blue keyboard and breathing green lid without CCC, but otherwise would prefer to not have CCC installed. All of the worthless bloatware part of CCC is gone.
    If anyone finds it useful and want to say thank you, they can use this link for Brother @j95.
    Papusan, Dr. AMK, j95 and 1 other person like this.
  3. Dr. AMK
    Dr. AMK The Strategist
    Nice mod, your efforts really appreciated.
    j95, Papusan and Mr. Fox like this.
  4. Mr. Fox
    So, has anyone else tried this? It works much better than the stock Clevo Control Center. If the only reason you install CCC is for LED control, this mod is exactly what you need.
    Papusan, Dr. AMK and j95 like this.
  5. ssj92
    ssj92 Neutron Star
    If only I still had a Clevo :p
    Papusan, j95 and Mr. Fox like this.
  6. j95
    j95 Notebook Deity
    Updated Hotkey3.exe & hotkey_settings.bat
    Hotkey.7z
    PW: j95
    Papusan, Dr. AMK and Mr. Fox like this.
  7. Papusan
    Finally can people get rid of most part of the unwanted Bloat. Sofware should be developed in this way. Aka you pick what you want. Good job, bro @j95 +rep:)
    Dr. AMK, Mr. Fox and j95 like this.
  8. j95
    j95 Notebook Deity
    Thanks man. FCU/RS3 new startup behavior many times overrides delayed tasks (5~10 sec) depending on resource load (applications must comply with M$ startup performance conditions in order to receive certification). Hence 13 sec delay.
    Update: hotkey task.
    DreDre and Papusan like this.
  9. j95
    j95 Notebook Deity
    Update: Hotkey3.exe & hotkey task.
    Hotkey.7z
    PW: j95
    Code:
    CRC32: 341B5D2D
    Papusan likes this.
  10. j95
    j95 Notebook Deity
    Papusan likes this.
Similar Threads - Hotkey P870xMx (and
  1. Allu D.
    307
