Can't get DVB-T USB tuner to work. CE6230 CE9500B1
Discussion in 'Accessories' started by Phil, Oct 9, 2009.
  1. Phil
    Phil Retired
    I've got this DVB-T tuner from Dealextreme:
    I put in my laptop and then I get a message device 'CE9500B1' found. I put the CD in. I get a menu and choose install driver. Error message: "you must install BlazeDTV first".
    I install the software, after that I try the driver again. Same error message.
    After that I install the driver manually. Seems to go ok. This device appears in the device manager:
    When I start the Blaze DTV software I see this device:
    When I click "Scan" nothing happens. I can't click properties.
    I tried a different driver and software: ProgDVB
    I get this error message:
    From my TV I know I have a good DVB-T signal in the same spot.
    Any ideas?
  2. paper_wastage
    paper_wastage Beat this 7x7x7 Cube
    one way would be to try using Windows Media Center (especially in Windows 7, where most drivers(even generic ones) can be found via windows update)
    try removing the drivers and reinstall, then plug it in another USB port...
  3. Phil
    Phil Retired
    I'm running Windows XP SP3. I don't think I can add Media Center without reinstalling.
    I tried removing driver and installing in another USB port but that did not help.
    Thanks for your suggestion by the way.
  4. saimen79
    saimen79 Newbie
    Hi Phill
    i have the same usb stick and it doesn't work on windows 7. I'm searching for 2 weeks now for the drivers. Can you maybe send me the driver you are using?
    Thank you a lot
  5. Phil
    Phil Retired
    Sorry Saimen, but I have no idea where I've kept them.
    I found them through Google. Shouldn't be too hard to find them.
  6. TwiztidKidd
    TwiztidKidd Notebook Evangelist
    This device usually gets detected as ce9500 but the ce6230 driver works best. Cancel any lookup, windows update for this device when asked and install the drivers from the attachment. GBPVR has great support for dvb-t usb sticks and the software is free.
  7. saimen79
    saimen79 Newbie
    thanx Twiz57, but when i launch the setup i receive an error:
    There was a problem starting streamci. The specified module could not be found.
    i also tried the compatibility mode, but the same error
    THANK YOU VERY MUCH
