Can't get Corsair Force MP400 SSD to work in GS65 Stealth Thin -laptop. Combability issue?
Discussion in 'MSI' started by kko, Oct 9, 2021.
  1. kko
    kko Notebook Enthusiast
    I'm at the PC repair shop.
    The BIOS shows that both the Linux and Win10 boot from the Samsung SSD.
    But both the Samsung and WD have an EFI partition. So I'm a little confused.
    We just removed the WD and try to boot with the Samsung only.
  2. kko
    It booted successfully to Win10 login screen without the WD SSD. Now putting in the Corsair SSD.
  3. kko
    Goes into boot loop when the Corsair is in. But at least it booted from a USB drive. Using Linux USB boot to check what drives are visible.
  4. NeXt3R
    NeXt3R Notebook Evangelist
    and is possitible see bios ?
    edit
    or here is some "usefully" domains
    f2 + Lalt + Rshift + Rctrl -admin mode ,.,.hotkey in bios
    BOOT/SATA SUPPORT
    ADVANCED/PCH-IO/SATA CONFIGURATION
    ADVANCED/NVME CONFIGURATION
    but must be visible in bios .,,.or BASIC SETUP- try SATA CONTROLER "AHCI"
  5. kko
    Nope, Linux USB stick boot crashes, and Win10 USB boot stick doesn't work (just goes into boot loop).
    Can't even access bios... It shows the MSI logo, and after a few bootloop iterations the logo is accompanied with "repair mode" text.
    I have "Fast boot" disabled though.
    Now we replaced the Corsair SSD with additional SSD that the repair shop had, and it boots fine to windows.
  6. NeXt3R
    booloop .,,.on MSI splash screen ??
    windows usb / CMD "shift + f10"
    diskpart
  7. NeXt3R
    or you only had the wrong piece ,.,.or bad FW inside
    edit ,,.removed bad info
  8. kko
    Yeah the bootloop only shows the MSI splash screen.
  9. NeXt3R
    MSI support can also be a problem !! old RST ROM / NVME driver in BIOS
    these 4TB nvme are modern
  10. kko
    Can installing Samsung nvme drivers or the RST drivers on windows affect booting to bios in any way? I'm guessing no...
