Can't enable SLI, driver and control panel disapear, help
Discussion in 'Sager and Clevo' started by Brent R., Jul 9, 2017.
  1. Brent R.
    Brent R. Notebook Evangelist
    Hello,
    I have been trying to enable SLI, when I do so I have to restart once I restart the drivers are gone and control panel is gone, it also does this on 378.66 how can I fix this? Thanks
  2. namaiki
    namaiki "basically rocks" Super Moderator
    What model laptop do you have? Have you changed anything, hardware or software recently?
  3. Brent R.
    np9377sm-a the only software I have tried to change is in Nvidia Control Panel I am trying to enable SLI but when I do that I have to restart and once I restart then the drivers disappear, control panel disappears, so I have tried a few different drivers and haven't gotten anything to work properly, any help would be great!
  4. namaiki
    Did SLI work previously?
  5. Brent R.
    yes it has always worked fine, I have a dual boot win7 and win10, in windows 7 SLI works fine control panel works fine, but i windows 10 I have to install the driver every boot and I never get SLI to work since after I install the driver I enable it in control panel then when I restart the drivers are gone
  6. namaiki
    Are you just using drivers from the NVidia website? I think Windows 10 can be picky with modded drivers. Does Windows 10 try to install any drivers by itself?
  7. Brent R.
    I download the new drivers from nvidia then I use D.D.U to uninstall everything, Then I go into nvidia control panel and turn sli on and restart to no drivers loaded at all no software loaded,..its very weird.
  8. joluke
    joluke Notebook Evangelist
    Did you try a new version of the nvidia drivers?
    I own a P377SM-A with 880M's in SLI and never had a single problem
  9. Prostar Computer
    You said this is only happening in Win 10, not in your Win 7 image? Is the Win 10 install a new/clean installation?
  10. Brent R.
    no Windows 10 is what I had first and was my daily OS, new drivers are always used and SLI always worked fine, I tried the newest drivers from Nvidia and no go...
