cannot remover outer case to clean fan
Discussion in 'eMachines' started by ailixin, Jun 27, 2013.
  1. ailixin
    ailixin Newbie
    My Emachines E642 laptop gets terribly hot and sometimes shuts itself off when getting too hot, often when watching movies or online tv. I think it is a built in safery feature that the it is turned off when getting too hot.
    I want to remove the case so that I can check the fan because I think it is either broken or full of dust. However after removing all the screws I found the case still very difficult to remove, it was opening up a bit in a corner or so if I really made an effort and used a tool for help. But I am quite sure I would have broken it I kept trying so I gave up and put the screws back again.
    Any tips of what obvious beginner mistake I made trying to remove the case or any other tips of how I can check the fan and/or stopping my laptop from overheating and turning itself off?
  2. downloads
    downloads No, Dee Dee, no! Super Moderator
    At first glance it looks pretty much identical to E627. Here's a service manual with disassembly instructions for E627- check if it will do.
