Can raid nvme speed up to 3,4gbps on laptop
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Djadit, Sep 4, 2020.
  1. Djadit
    Djadit Notebook Evangelist
    Hello
    I need help
    I just wanna make raid 0 using adata sx8200 pro and 970 evo
    Can speed better than single ssd ?
  2. saturnotaku
    You should always try to run a RAID array with identical drives. Unless you have a good backup solution and are running I/O intensive business/scientific applications (game loading time is not one of those cases), RAID-0 is not worth it.
    Aivxtla and Starlight5 like this.
  3. Aivxtla
    Aivxtla Notebook Evangelist
    4K Random Reads/Writes are what give you the responsiveness and those actually take a slight/negligible hit in RAID0. Unless you’re doing sequential file transfers it probably won’t really do much for you, other than maybe just giving you a single logical drive. As @saturnotaku mentioned above, it’s not going to do much to boost loading times or anything. If maximizing sequential speeds is your goal then yeah RAID0 will be good.
  4. Spartan@HIDevolution
    100% agreed. Snappiness is all about the 4K Random Read/Write.
    Here is an example of my Western Digital SN730 SSDs both in RAID and single drive setup benchmarks:
    AS SSD Benchmark - 2x Western Digital PC SN730 NVMe SSDs in RAID 0 [64K Data Strip Size]
    AS SSD Benchmark - Single Western Digital PC SN730 NVMe SSD
    CrystalDiskMark- 2x Western Digital PC SN730 NVMe SSDs in RAID 0 [64K Data Strip Size]
    CrystalDiskMark - Single Western Digital PC SN730 NVMe SSD
    Dr. AMK, custom90gt and Aivxtla like this.
  5. Djadit
    Thankyou very much
    What Crystalldiskmark increase write host ?
