Can I use Macrium Reflect to keep multiple system images?
Discussion in 'Windows OS and Software' started by kylera, Aug 25, 2020.
  1. kylera
    kylera Notebook Consultant
    Given that each Windows patch these days seems to screw something over, I got the idea of buying an external SSD or flash drive, making it bootable and having it hold the last few system images prior to Windows update, so I can roll back if needed.
    Or I can keep an image of the last Windows image while I experiment with LTSC or even Linux.
    Is this a feasible scenario?
  2. Spartan@HIDevolution
    Macrium Reflect Usage Guide:
    Here is how to create a bootable Flash Drive and partition it to have a single USB Stick containing both the Macrium Reflect Rescue Disk and a Backup Image partition in that rescue disk itself. So if you have a large/fast USB Flash Drive, you can use it to both boot into the Macrium Reflect program without installing and use its second partition to create a backup image of your computer
    What I usually do when I buy a new computer, the moment I turn it on and before even getting into the Windows setup wizard I boot straight away to the Macrium Reflect Rescue Disk, create a full backup of the local disk including all its partitions. That way I always have a backup of the untouched factory image should I ever need it in case I changed my SSD later or had an issue that prevents me to use the local restore option
  3. kylera
    I was browsing through the very thread you created with those two videos when the alert popped up XD
    The answer sounds like a resounding yes.
