Buying a RTX 2070? My advice...
Discussion in 'Desktop Hardware' started by Zymphad, Apr 19, 2019.
  1. Zymphad
    Zymphad Zymphad
    My advice is buy the cheapest RTX 2070 you can. No matter the price, you get the same chip, same ram speed/bandwidth etc. Far as I know all the custom RTX 2070 come with 8 phase VRM or better.
    You may pay more for "binned" and pre-overclocked.
    I can tell you the 2070 overclocks well, and easily. Every review of the cheaper 2070 I have seen overclock just as well as the binned chips. So I guess I don't even know what that means from NVidia if overclock results are the same.
    I bought the Gigabyte Windforce 3 for $450 on sale, it was the cheapest I could find. It's overclocked 188 on the core and 700 on memeory. It boosts to 2050 and stays around 2020 on Division 2 at 70C. 2070 shouldn't thermally throttle until 88C, so plenty of thermal room. I recommend just get the 2070 you can afford and know that it will like overclock like a monster.
    ekkolp likes this.
  2. ekkolp
    ekkolp Notebook Evangelist
    If you are not afraid about warranty etc I would commend kraken g12 mod in order to get nicer temps.
  3. Zymphad
    Zymphad Zymphad
    No need. If one is going to take the time and void warranty by removing the shroud, just strap two 120mm static pressure fans for $30 using zip ties should see temps about 10c drop.
    Especially when the card already has fan connectors that should be able to run 120mm fans fine got 3 on my card.
