Buying a replacement GPU(980M) advice(P751DM-G)
Discussion in 'Sager and Clevo' started by Dichotomy, Jan 13, 2020.
  1. Dichotomy
    Dichotomy Notebook Enthusiast
    Hiya,
    So, with the help of friendly NBR'ers, i managed to pinpoint that my GPU is on it's way out.
    I am just looking at where to buy a replacement 980M - since it covers all the games i play at a fair price. The official reseller in the UK quoted a hefty price, as i'd have to send it back in for an out of warranty repair.Tbh, i really enjoy doing this kind of thing myself and am more than capable. However, i have little experience with buying replacement laptop parts, and much to my delight... it's not that delightful! I've trawled though a number of ebay/aliexpress resellers, they all seem to be coming from Shenzhen or thereabouts, which is expected.
    At the moment, this one looks like the best option compared to the others. It offers fast shipping(the rest are all 20-40days) and the store seems to have a successful/high rating, despite not selling many of these cards previously:
    New Original GTX 980M Graphics Card GTX980M with X-Bracket N16E-GX-A1 8GB GDDR5 MXM For Dell Alienware MSI HP via free DHL/EMS
    Any of you have experience with this reseller or buying cards on aliexpress/ebay? I know there is lots of concern about modded/fake components but tbh, that could happen with anything on ebay/aliexpress. I wish this experience was the same as it would be if i were looking for a new desktop component!
  2. TheGreatAnonymous
    TheGreatAnonymous Notebook Consultant
    You got a similar model to me so I'll chime in and just say be careful with eBay cards especially ones coming from Shenzhen. I've tried a couple of those when my 980M died and they refused to work. They are usually going to be non-GSYNC versions as well so you'll lose that functionality if you have a DM-G model so also keep that in mind. Also confirm if they ship with the x-bracket on the back (mine didn't, had to reuse my old one which is kind of a pain to remove and swap over) or you won't be able to mount the heatsink. They seemed like legitimate cards they just wouldn't work for some reason. Only replacements that would work for me were Clevo cards. Maybe you'll have better luck (those prices can be tempting) but just make sure the seller accepts returns.
    Dichotomy likes this.
  3. Dichotomy
    Thanks for the reply. Yeah. I went ahead with the seller I linked. It is a risk, but apart from finding someone on here - there's not many options unless I send it back to the official vendor. This one comes with the X bracket.
    On a positive note, this reseller accepts returns and has already messaged me to find out what the model of my laptop is, to confirm it will work. They've also asked the situation of my current card not - sure why yet. Perhaps they want to buy it off me? Strange, though I plan on keeping it since it works for low settings on most games. Yes, i won't have G-sync but I always used an external screen which isn't G-sync, so I don't think it's something I've ever used.
    I mainly just want to get this laptop back to running games at a decent spec again, I plan on getting rid of it in 2021 and going back to building small form factor desktops.
  4. Meaker@Sager
    Selling mxm cards is tricky as most users don't know what they are doing. They are building up a picture to see what you are doing.
  5. TheGreatAnonymous
    They always listed my model as compatible as well, but no dice everytime, lol. Like Meaker said MXM can be tricky in regards to compatibility, but I would be curious to know if the replacement works for you.
  6. Dichotomy
    Yeah, agreed. I told them the issue, seemed to understand. I suppose they wouldn't want to be accused of a faulty component if it was something else causing the issue. I'm in the fortunate position that my GPU still works, so I'll definitely know if the one they send me isn't right straight off the bat.
    I'll update you went I've fitted it. Got all my thermal pads and paste ready to go, the card should be here some time next week.
  7. Meaker@Sager
    Good luck :)
  8. Dichotomy
    Decided to stress test my GPU one last time to double check my results were synonymous. Now, under any load the laptop starts emitting a high pitched whine, intensifying as loads increase before shutting off. Any idea what this might be? Am thinking it might be a hazard at this point . Strange because the card is running around 55/60degrees. I normally associate a card dying with unflappably high temps, but i suppose it's just been well used these last 5 years!
  9. Meaker@Sager
    Sounds like coil whine, usually not a sign of failure.
  10. Wolan82
    Wolan82 Newbie
    I might be in the same boat as you however first have to try and find a proper thickness of the thermal pads to see if the card is toasted or is not cooled properly
