Business/Work Ultraportable under $1000 (Rs 65000)
Discussion in 'What Notebook Should I Buy?' started by ari1719, Sep 6, 2016.
  1. ari1719
    ari1719 Newbie
    General Questions
    1) What is your budget?
    $1000 (+/-200)
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    3) Where will you buying this notebook?
    India
    a. Like: Apple, HP, Dell
    b. Dislike: Asus, Lenovo
    No
    Writing, media playback, multitab browsing, large and image centric PDF files, general office work
    Yes to both. Usually colleges and libraries.
    Not likely. Perhaps really old ones like Call of Duty or Age of Empires. I've got a desktop for handling games.
    8+ at least.
    Online from Amazon or similar is okay.
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    OS agnostic.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer?
    Between 1366*768 and 1920*1080
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Doesn't matter.
    Build Quality and Design
    Somewhat, since this will end up on the Teacher's desk in a college.
    Immediately!
    At least 3 years.
    Notebook Components
    SSD preferable. 128 gigs should do. I have external HDD for the rest.
    Nope, no moving parts if possible.
  2. ari1719
    ari1719 Newbie
    Just to clarify, I'm looking at alternatives of the Apple Macbook Air.
  3. derpsauce
    derpsauce Notebook Consultant
    Have you looked at the XPS 13 or it's enterprise class counterpart? They seem to fit what you need especially as a MacBook Air alternative.
  4. ari1719
    ari1719 Newbie
    Thanks Dansauce . The XPS 13 range looks attractive but there seems to be some pricing issues in India. The price of the lowest Xps is 30k more ($400 more) so they're at par with the Macbook Pro range. Importing may be an option but I'd rather have domestic shipping. :'(
