Build a Mini PC with a Micro-STX MOBO and MXM Gpu
Discussion in 'Desktop Hardware' started by sicily428, Jun 12, 2017.
  1. sicily428
    sicily428 Donuts!! :)
    Hi! there are these new mobos micro-stx with mxm gpu. I'm really curious about them :)
    Asrock created this H110-STX MXM
    http://asrock.com/IPC/overview.asp?Model=H110-STX MXM
    Asrock created this Z270M-STX MXM
    https://smallformfactor.net/news/asrock-z270m-stx-mxm-pictured
    https://www.kitguru.net/desktop-pc/...hows-off-micro-stx-deskmini-rx-gaming-system/
    ASRock DeskMini
    https://smallformfactor.net/news/asrock-micro-stx-updates-gtx-1080-working
    "Now aftermarket availability for upgrading down the road is a very valid concern but ASRock has iterated that they’re working with the MXM card vendors Aetina and TUL to ensure there are affordable and readily available upgrade options for future GPU generations (like Vega)."
    Silverstone RVZ04
    and MSI presented Vortex G25
    Aroc and ChanceJackson like this.
  2. sicily428
  3. sicily428
    Aroc, wyvernV2 and jaug1337 like this.
  4. sicily428
    Gigabyte BRIX GTX PRO
    http://www.legitreviews.com/gigabyt...lt-3-geforce-gtx-950m-dual-gigabit-lan_177440
    https://www.techinferno.com/index.php?/forums/topic/9772-gigabyte-brix-gtx-pro/
    Specifications:
    • CPU: 6th Generation Intel Core Skylake Mobile H (4+2)/Xeon (4+4e) Processor
    • Memory: DDR4 Dual Channel
    • Graphic: NVIDIA GeForce GTX 950
    Read more at http://www.legitreviews.com/gigabyt...m-dual-gigabit-lan_177440#xwXEDslmlqtJHtlA.99
    GB-BNi7HG4-950
    Features:
      • Processor: Intel Core i7-6700HQ Quad-Core (2.6GHz / 3.5 GHz)
      • Chasssis: Ultra compact PC design at only 2.6L (220 x 110 x 110mm)
      • Discrete Graphics: NVIDIA GeForce GTX 950 w/ 4GB GDDR5 (GTX 965M)
      • Storage:
        • 1 x M.2 SSD (2280) PCIe slot directly connected to the CPU (No M.2 RAID possible)
        • 1 x M.2 SSD (2280) SATA/PCIe slot connected to the Intel HM170 chipset
        • 2 x 2.5” SATA III HDD/SSD, 7.0/9.5 mm thick (RAID capable)
      • Memory: 2 x SO-DIMM DDR4 slot (2133 MHz)
      • Connectivity: Intel Dual Band Wireless-AC 8260 w/ Buetooth 4.2 NGFF M.2 card
      • Ethernet: Intel Gigabit Lan (Intel i219LM)
      • 2 x USB3.1 (1* USB Type-C w/ ASmedia controller)
      • 3 x USB 3.0
      • 3 x Mini DP (Max Resolution 3840×2160 @ 60 Hz)
      • 1 x HDMI 2.0 (Max Resolution 3840×2160 @ 60 Hz)
      • Headphone and Microphone jack w/ Realtek ALC255 audio
    Read more at http://www.legitreviews.com/gigabyt...iew-gb-bni7hg4-950_188376#09DRRbyBfpP5wdlT.99
    https://www.mobile01.com/topicdetail.php?f=513&t=4988431
    http://ua.gecid.com/tags.php?s=nvidia+geforce&s2=intel&idt=0&b=52
    https://kknews.cc/zh-mo/digital/y5mlzb.html
    https://gigglehd.com/gg/hard/493520
    Aroc, wyvernV2 and kosti like this.
  5. sicily428
    Gigabyte Brix VR GB-BNi7HG6-1060
    http://www.gigabyte.us/Mini-PcBarebone/GB-BNi7HG6-1060-rev-10#ov
    • Features Latest Intel® 7th generation Core Processors
    • Ultra compact PC design at only 2.6L (220 x 110 x 110mm)
    • Discrete Graphic GeForce® GTX 1060
    • 2 x M.2 SSD (2280) slots
    • 2 x SO-DIMM DDR4 slots (2133 MHz)
    • Intel® IEEE 802.11ac, Dual Band Wi-Fi & Bluetooth 4.2 NGFF M.2 card
    • Supports a 2.5” HDD/SSD, 7.0/9.5 mm thick (6 Gbps SATA3)
    • 2 x USB3.1 (1* USB Type-C™)
    • 3 x USB 3.0
    • 2 x Mini DP
    • 2 x HDMI 2.0
    • Intel Gigabit Lan
    here gpu is soldered :(
      File size:
      1.8 MB
      17,074
  6. sicily428
    Gigabyte Brix VR
  7. Support.2@XOTIC PC
    Wasn't impressed with previous iterations of Brix, but this looks kinda cool.
    sicily428 likes this.
  8. sicily428
    HP Z2 Mini G3
    https://www.computerpoweruser.com/article/24227/review-hp-z2-mini-g3
    On the unit we tested, in addition to the on-die Intel HD Graphics 530, there’s also a discrete GPU in the form of NVIDIA’s Quadro M620, which sports a cut-down version of the Maxwell-based GeForce GTX 750 Ti’s GPU, with 512 CUDA cores, 32 texture mapping units, 16 ROPs, and 2GB GDDR5 running on a 128-bit bus. Although it’s not much of a gaming GPU, this 1TFLOP- (single precision floating-point) capable GPU is significantly better at managing the workloads typical of CAD applications. This is an MXM card, and together with the SO-DIMM slots, are about the only components in this system that can be called mobile-grade."
    Aroc likes this.
  9. Support.2@XOTIC PC
    That's a pretty slick system, and in workplaces where a thin client isn't appropriate it would be great.
  10. jaug1337
    jaug1337 de_dust2
    You are doing gods work bro
