Bricked Razer Blade Advanced 15
Discussion in 'Razer' started by mehtenj94, Jul 10, 2020.
  1. Sk9zy
    Sk9zy Notebook Enthusiast
  2. amihail91
    amihail91 Notebook Evangelist
    If I remember right that's definitely the right chip type it's detecting. Are you able to get a read out of 16mb? Attaching the clip is very finnicky yes.
  3. Sk9zy
    i’m still struggling to get the programmer on the chip to read it.
  4. amihail91
    Pin 1 isn't the one that's colored in, maybe it's that?
  5. Sk9zy
    i watched a video and it said that the indent on the chip indicated pin 1 and still no luck, i’m gonna have another IT guy i know see if he can do it he knows some knowledge on it but if all doesn’t work i guess i’d just have to send it in
  6. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    NO!! Needs to be GD25Q128!!!!!! You have selected 8MB flash, the Razer BIOS ROM is 16MB!!!
  7. Sk9zy
    Ok I was able to select it and actually get a read! But now what do I do? I knew all steps all the way up until then
  8. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Make sure the read is valid. save it to a rom file, and try to open with amibcp to see if its valid. that means your clip is well seated. click erase, wait 5 minutes, then you can now flash the recovery BIOS image you get from the razer bios updater or if you downloaded somebody elses bios.
  9. Sk9zy
    I am using the CH341A programmer software but I am not given a option to save as a .rom file
  10. Sk9zy
    I saved the files by save as and selecting all files and naming it chip.rom opening in amibcp said failed to open file, does that mean that the bios is not on that chip?
