Bricked Razer Blade Advanced 15
Discussion in 'Razer' started by mehtenj94, Jul 10, 2020.
  1. mehtenj94
    mehtenj94 Notebook Enthusiast
    Hi Guys ,
    I have a 2019 Advanced Razer Blade 15. When performing the bios update for 1.04 to 1.05 windows threw a Bsod and now the monitor is blank . Tried the common steps but no luck with getting the system to boot . Only the keyboard lights up . Is there anything I can do here ?
  2. senso
    senso Notebook Deity
    If you can get a full BIOS dump you could try flashing it using an hardware programmer.
    MagillaGorilla likes this.
  3. mehtenj94
    Unfortunately, I don’t have any experience working with hardware programmers even if I do have the bios file . Is there another way via an usb or something ?
  4. MagillaGorilla
    MagillaGorilla Notebook Guru
    Hi, bummer.. Unfortunately senso is right, you'll need a chip programmer.
    You can either -
    - Order the tool and learn how to use it (plenty of help in this Forum)
    - RMA with Razer/Microsoft/whatever warranty/insurance you have
    - Ship your blade to someone and pay them to flash it for you
    Best of Luck
  5. mehtenj94
    Is there a thread that I can learn this from ? I’m willing to try it out if I can avoid the Razer RMA
  6. senso
    This thread is fine.
    You will need a basic CH341A programmer with a SOIC clip, you can buy that from eBay or Aliexpress for less than 5$, then you will need to take your laptop apart and post some photos so we can help you identify the correct BIOS chip.
  7. mehtenj94
    Do you think this is alright ?
    https://shopee.sg/product/87828950/6120738629?smtt=0.0.9
    Besides , I had a word with Razer tech support and it’s absolutely awful . After so much time verifying data like every serial number part number and so on for charger and laptop and me explaining my problem clearly , they sent me an email asking me to try booting into safe mode . Lmao . I absolutely regret my choice of getting a Razer rather than another Alienware which I have had for 10 years (2 laptops ) and tech support has always been top notch with on site service . Razer is just the opposite it seems
  8. MagillaGorilla
    Yea that programmer will do the job
    Sorry you have to go through Razer.. they make AWESOME products, but their customer support is trash.
    I recommend buying Razer laptops from Microsoft Store, Best Buy, or Amazon because of their warranties, and customer support.
    Terreos likes this.
  9. mehtenj94
    I’ve ordered the programmer while I’m also trying to get Razer to do a RMA . I’ll update here once I receive the tools or Razer does the RMA
  10. amihail91
    amihail91 Notebook Evangelist
    Flashing the BIOS chip is so simple man, I wouldn't put myself through the Razer Support bonanza.
