Brands effectiveness at cooling
Discussion in 'Gaming (Software and Graphics Cards)' started by deanovip, Sep 10, 2017.
  1. deanovip
    deanovip Notebook Guru
    A bit random I toting between Lenovo, Asus and MSI. But I just want to check these brands are good enough to handle gaming in thermals. I've done so much research and have read some horror stories about certain brands.
  2. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    @deanovip you should check specific models, not just brands.
    TBoneSan likes this.
  3. deanovip
    Sorry, I was looking at the Lenovo Y520 Legion, that had an i5 and 1050ti.
    Asus ROG FX502VM i5 and 1060.
    NAI GE62 7RE i7 and a 1050ti.
    Starlight5 likes this.
  4. don_svetlio
    don_svetlio Notebook Virtuoso
    Those are different classes of devices with different intentions. The Y520 is a barebones and does a decent job at cooling its components assuming you don't mind the noise. The FX502VM runs warm because it has a focus on lower fan noise and a slimmer profile. If you undervolt and repaste, it runs decently cool as well as being quieter than the Y520. The screen, however, is awful. Any laptop with a TN screen (in 99% of cases) should be avoided. The GE62 has good thermals at at the cost of fan noise and battery life. It has a very small battery because the majority of the back of the machine is taken up by heatpipes.
  5. deanovip
    Thanks... I really appreciate your help and struggling with the right choice. The Lenovo is £900 for the i5 7300hq and the 1050ti. Where as the msi is £1000 more but has the i7 7700hq. You have ruled out the Asus for me, the only reason i considered that was the 1060.
  6. deanovip
    Sorry to throw in the mix MIS GP62 MVR Leopard Pro is an i5 with a 1060. Maybe that would be a sweet spot. I'm having trouble finding battery life and screen info for that.
  7. don_svetlio
    Avoid the GP/GL series. Also, check out the GL502 - that's the same model as the FX502 but with a high-end IPS screen
  8. deanovip
  9. don_svetlio
    Yes. It has a M.2 slot for an SSD and a 2.5" drive bay for a HDD (I know because I have the VT model of that chassis in a 250GB + 1TB config)
  10. deanovip
    Lastly done out of the 3, Lenovo y520, msi ge62 or the Asus? Which would you buy?
    I just want to say a big thank you as you have really helped me out.
