Bootable device not found
Discussion in 'Dell' started by KCcc, Dec 31, 2017.
  1. KCcc
    KCcc Newbie
    Hey guys.
    I have a Dell Inspiron 7577.
    I recently installed a new hard drive, Samsung 960 Pro, and had to use a data migration tool to move my OS from one drive to another.
    After this was done, I noticed that my new drive was split into 3 partitions: D drive, Z drive, and a hidden drive.
    D drive was the main drive with 450+gb.
    The Z drive was around 500mb and was labeled system.
    The z drive was visible in My Computer, but i cannot access it due to some permission.
    I didn't like the look of there being a Z drive, so I tried to merge it using the same software, but it didn't allow me to. I then decided to make it a hidden drive, which completed successfully. Nothing went wrong then and I was able to use my computer like normal.
    The problem is that, after rebooting, my computer told me that no bootable devices were found.
    I tried a number of solutions including :
    1) going into bios and turning off secure boot.
    2) going into bios >> boot sequence >> Add boot options - this throws an error that says file system not found.
    3) using legacy boot
    Is this because i hid the system partition? How do i unhide it?
  2. ThatOldGuy
    ThatOldGuy Notebook Virtuoso
    Change your boot options between AHCI and IRST in the bios.
  3. KCcc
    KCcc Newbie
    How do i change it to IRST? The only option I see is RAID and AHCI, both of which don't work.
  4. Kasdder
    Kasdder Newbie
    Chaning your boot options between AHCI and IRST in the bios it so difficult , this is not like booting USB ,
  5. kojack
    kojack Notebook Virtuoso
    I had this happen to a small USB drive I was using. I could not even format it to fix it. I had to use a special software package from a local computer store to restore the full drive to normal. When I moved to my 2tb firecuda from my HDD, I used AMOEI backupper. There is an option to move your entire drive to a new drive and it worked great. No messing about with changing things etc.
  6. custom90gt
    custom90gt Dellerator Super Moderator
    I am curious why you would copy your OS to the new drive? Seems like it would be worth it to set bios to AHCI and do a fresh install so you can really take advantage of the 960 pro...
  7. kojack
    What 960 pro>?
  8. custom90gt
    The one the OP talks about in the OP?
    kojack likes this.
  9. kojack
    Ha ha...I thought you were referring to me... ha ha
    custom90gt likes this.
  10. custom90gt
    oh lol. Yeah I should have quoted the OP. Just doesn't make sense to clone a drive when you're going from something probably entry level to a 960 pro. Why waste the money buying a 960 pro vs something else.
    kojack likes this.
