"Bluetooth Radios" vs "Bluetooth" in Device Manager.
Discussion in 'Panasonic' started by TheSpiritOfRadio, Mar 11, 2018.
  1. Shawn
    device manager photo of 50 hr CF 31 mk3 ..win7 32 bit...MC8355 wwan card ..Intel 6235
    Installation of OS was done by using official recovery Panasonic DVD set
  2. TheSpiritOfRadio
    TheSpiritOfRadio Notebook Geek
    Come to think of it, the person who I just bought the Toughbook from sent me recovery discs as well. 1 and 2. How would I employ those properly in terms of what I am attempting to fix?
  3. Shawn
    Verify in bios that the DVD will boot before the HDD.
    put disk one into the dvd and reboot.
    It will ask questions then
    DELETE everything and reinstall the drive/os to factory new condition.
    Then you will need to manually install the WWAN driver package after you download it from Panasonic, If you have a WWAN card.
    AFTER the drive is restored using all original hardware and confirmed working, You can swap the 7260 back in..BUT
    The 7260 ac will work nicely, but I never could get the Bluetooth to work on anything but the original 6235. I have seriously tried 6-10 different cards and spent days on this issue.
    7260 will require a download from Intel
    802.11ac is way more important than bluetooth for me. Personally, I find BT to be a PITA.
    If you want both, I suggest a micro bluetooth usb stick.
    I have gotten a micro usb BT to work using a miniPCIE to usb adapter in the WWAN slot.
    Metal case means the range sucks.
  4. TheSpiritOfRadio
  5. Shawn
    @ thespiritofradio
    Are you in USA?
    If so, I will send you are card to experiment with.
    It's a Bluetooth only card. Mini PCIE fits in WWAN socket.
  6. TheSpiritOfRadio
    I am in the USA.
    Ill send you a pm.
    NVM
    I cant seem to PM you.
    Just to make sure, the recovery discs look like this correct? These will install a full win 7 OS with correct drivers?
  7. Shawn
    pm started
    yes those are the proper disks.
    they will also create a recovery partition on the hdd.
    you can access the recovery through the bios.
  8. TheSpiritOfRadio
    So I decided to go back and reread this post, must have missed it the first time. Turns out I missed 1 bluetooth driver at the bottom that needed uninstalling. Just now figured it out.... I literally uninstalled 1 intel corporation IVT Bluetooth driver down at the bottom of my default programs and the default windows driver immediately showed up and started installing. As you can see in the lover corner it popped up. I am running the AC7260 card.
  9. TheSpiritOfRadio
    It does show up, however, now I am missing 5 others.
  10. Shawn
    7260 really...
    keep me posted. make sure you can enable bt and connect to it.
    Maybe the mk4 will recognize the 7260 BT and the mk3 bios will not.
