Bluetooth not working
Discussion in 'Networking and Wireless' started by arsalan786, Jun 28, 2020.
  1. arsalan786
    arsalan786 Notebook Consultant
    Hello, I really need help to figure out how I can fix my bluetooth. Since the day I got this laptop I was never able to use bluetooth I thought it could be settings issue, I am trying to use my airpods for it I need bluetooth to work. Anytime I try to discover a device in bluetooth nothing shows up. I opened my laptop back cover to see if anything is loose and everything looks fine. This is the picture of the adapter. https://imgur.com/gCMNeBr
    Laptop which I have is:
    https://eurocom.com/ec/drivers(257)M5Pro
    Windows I have is:
    Windows 10, version 1909, osbuild: 18363.900
    Wifi adapter i have is
    2-in-1; 802.11ac WLAN + Bluetooth 4.1; M.2; Killer 1525AC; 2x2; Qualcomm; M.2 2230
  2. Jdpurvis
    Jdpurvis Notebook Evangelist
    First, (if you haven't already done so), I would check to make sure you have the most recent BT driver installed - this is often separate from the Wifi driver - and that it is visible in Device Manager. Then I would look for another BT device to see if the problem is with BT in general, or with your airpods. You may want to also check under Sound - sometimes the device has been discovered, but Win is set to use speakers by default.
    Good luck.
    Joe
  3. arsalan786
    airpods i am using with my phone works fine. actually no bluetooth device is able to find when i do a search. can you please tell me which bluetooth driver i need because on my laptop manufacturer website i can't find. thanks
  4. Jdpurvis
    There are drivers on the Killernetworking site for the 1525, but it appears the bluetooth drivers may be lumped in with the others, and with their software. Chipset is Qualcomm. Dell used the 1525 and lists drivers here: https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=7hw54 and the BT driver may be here: https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=7hw54 . You could try these and roll back if they don't work.
    Hope it goes well. BTW, what BT and Wifi drivers does Device Manager think you have?
    J
