bluetooth missing the tray icon, XP Pro
Discussion in 'Lenovo' started by miro_gt, Nov 26, 2007.
  1. miro_gt
    miro_gt Notebook Deity
    I can't find the utility program that shows the bluetooth on the taskbar. The bluetooth by itself works, but before I did a clean install on XP I remember I had that icon. Where to find it ?
    I installed both the MS bluetooth support, and the thinkpad bluetooth with enhanced data rate drivers.
    that icon listed the devices that you can connect via the bluetooth, like keyboard, mouse, fax, etc.
  2. Arki
    Arki Super Moderator
    Control Panel > Bluetooth devices. ;)
  3. aan310
    aan310 Notebook Virtuoso
    alternatively, if you have x64 XP, there may be a driver issue. also, that may be a setting you have to not display it, or it could be because you have no active bluetooth devices.
  4. panteedropper
    panteedropper Notebook Deity
    is the bluetooth power switched on? as mentioned before you can enable the icon through the control panel.
  5. miro_gt
    thank you. Sometimes I miss stupid things like this, lol.
    however, I must have had some different driver for the bluetooth before I reinstalled XP, because when I click on that icon it used to show a list of different devices that I want to connect to .. and now it doesn't show that list. Hm .. not a biggie I guess
  6. Arki
    I believe there are two Bluetooth drivers, the one for Microsoft and the Lenovo one, I tried to install both but it seems whichever you install, it overrides the others settings? I'm not sure, so if anybody has any clarification on this, it would be helpful.
  7. apoddar
    apoddar Notebook Consultant
    hey watusp the bluetooth icon on the system tray could get fix in too ways one is that you have it checked in "msconfig" that is actually the main one. and the other one is that you need to press "fn - f5" that shoudl activate the access connections and through that you can actually do everything through ther
