bit of help on java...little quickie
Discussion in 'Off Topic' started by alexpre888, Dec 11, 2013.
  1. alexpre888
    alexpre888 Notebook Consultant
    how do I write a program that rotates a given string n characters to the right. For example, if
    the input to my program is:
    rotatemeplease 4,
    then the output is:
    easerotatemepl
    anyone?
    EDIT:
    public class Rotatemetest
    public static void main(String[] args)
    String word = "rotatemeplease";
    String Four = word.substring(word.length() - 4, word.length());
    System.out.println(Four);
    the Output ended up like this:
    ease
    Grr...is there something I'm missing?
  2. Jarhead
    Jarhead 恋の♡アカサタナ
    I remember doing something similar in C that involved bitwise operations...
    Let me code up something real quick to see how to do it in Java...
    EDIT: Found my C code for bitshift operations. Are you familiar at all with bitwise operations?
    I tried converting my C code to Java, though there are some difference between the languages that I need to account for...
    In the meantime, you could check out StackOverflow for tips: http://stackoverflow.com/questions/10306647/how-to-bitwise-shift-a-binary-string-in-java
  3. ajnindlo
    ajnindlo Notebook Deity
    You are very close. If you look at your actual output and compare it to your desired output, what do you notice? Keep in mind you are simulating a rotate by using other functions. Can that be done in one step, i.e. one function?
  4. TheCodeBreaker
    TheCodeBreaker 7H3 1337
    LOL, nvm, just realized this was an old thread.
    Four = Four + word.substring(0, word.length() - 4);
    This should work. I do not have a compiler for java installed. Tell me if you would like it for the general case too.
