Bigfoot Killer Wireless-N 1103 compatability
Discussion in 'Alienware 18 and M18x' started by rawhide85, Jun 11, 2011.
  1. steviejones133
    steviejones133 Notebook Nobel Laureate
    This should help out - grey goes in the middle if you had 6200 but they are labelled as you can see with little colour coded arrows.
  2. Locutus
    Locutus Notebook Consultant
    thank you .
  3. gseward
    gseward Newbie
    gil@UbNb11:~$ lspci
    00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
    00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
    00:04.0 Signal processing controller: Intel Corporation Device 0103 (rev 09)
    00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
    00:1a.0 USB Controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
    00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
    00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
    00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5)
    00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5)
    00:1d.0 USB Controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
    00:1f.0 ISA bridge: Intel Corporation HM67 Express Chipset Family LPC Controller (rev 05)
    00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
    00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
    01:00.0 VGA compatible controller: nVidia Corporation Device 1251 (rev a1)
    01:00.1 Audio device: nVidia Corporation Device 0bee (rev a1)
    02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
    03:00.0 Network controller: Atheros Communications Inc. AR9300 Wireless LAN adaptor (rev 01)
    04:00.0 USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04)
    gil@UbNb11:~$ dmesg | grep ath
    [ 21.894427] ath9k 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
    [ 21.894439] ath9k 0000:03:00.0: setting latency timer to 64
    [ 21.903615] ath: EEPROM regdomain: 0x6a
    [ 21.903616] ath: EEPROM indicates we should expect a direct regpair map
    [ 21.903618] ath: Country alpha2 being used: 00
    [ 21.903619] ath: Regpair used: 0x6a
    [ 21.906927] ieee80211 phy0: Selected rate control algorithm 'ath9k_rate_control'
    [ 21.907242] Registered led device: ath9k-phy0
  4. misft33333
    misft33333 Notebook Consultant
    I have been searching around and on Dell's site, but it does not list it.
    Is this compatible with a Dell XPS 15 L502X even though Dell's site does not offer this card?
  5. bigtonyman
    bigtonyman Desktop Powa!!!
    Do you know how many antennas your system has? I think it would work fine if it has 3. If you only have two though, it might be better to just go with the 1102 with the dual antennas. As to drivers, you should be able to grab them right off of the killer wireless website. ;)
    Sent from my GT-I9100 using Tapatalk
Similar Threads - Bigfoot Killer Wireless
  1. low9
    2
    246
  2. etcetera
    1,007
