Bigfoot Killer Wireless-N 1103 compatability
Discussion in 'Alienware 18 and M18x' started by rawhide85, Jun 11, 2011.
  1. idie970
    idie970 Notebook Geek
    Welcome to the site! :D
    Since you said that you uninstalled the Network Manager, I imagine that you bought your m18x with the Bigfoot Killer Wireless-N 1103 wireless card.
    You will be able to download the drivers from Dell here: Drivers and Downloads | Dell [United States]
    Or you can download the drivers direct from Bigfoot's website (newer): Support
  2. locust76
    locust76 Notebook Consultant
    DON'T download the ones from Dell. They're very old and cause problems with iTunes and other programs that are fixed in the newest version from Bigfoot
  3. sdruley
    sdruley Newbie
    I made the mistake of downloading the old one from Dell and I got a blue screen error on the M18. So I downloaded the one from BigFoot onto a thumb frive. however when I proceeded to uninstall the older version in safe mode (with network) I got an error
    Tomorow I will call 1-800-ALIENWARE but surely need your advice as well.
    I have also attached a snapshot of my Network Adapters listed in the Device Manager. The file that I have downloaded (to be installed) is named:
    Killer1102-1103Setup_6_1_0_219_win7_64bit
    IS RESTORING THE ENTIRE SYSTEM TO FACTORY DEFAULT IN THE CARDS HERE>?
    Your help (collectively) has been a blessing
  4. bahnzii
    bahnzii Notebook Consultant
    Ugghhh...I'm at a loss :(
    Cards arrived a few days ago, finally had a chance to install one today in my m17x r3, install was no problem, however...
    I can't stop beating my head against the wall to solve an issue.
    I've tried both version of the Dell drivers and the latest version of the Bigfoot driver for the 1103 for Win7.
    The card connects to my router just fine, gets an IP, I can ping, tracert and perform an nslookup just fine...BUT, I cannot surf in either Firefox (normal and add-ons disabled) or IE 9.
    I have tried all 3 driver versions and both 2.4g and 5g on my Netgear WNDR3700 router.
    I double checked my antenna connections (white #1, black #3, grey #2) on the mini-card but I still can't resolve the issue.
    Anyone else with a similar issue??
    Help :(
    Oh and Merry Xmas everyone!!
  5. sdruley
    sdruley Newbie
    I restored to factory and everything is back to normal
  6. littleone562
    littleone562 Notebook Deity
    Bahnzii I think the Grey is in the middle.
  7. Aikimox
    Aikimox Weihenstephaner!
    Did you remove Intel wifi drivers before installing the killer?
  8. deepflash
    deepflash Notebook Enthusiast
    I've got the exact same problem with my bigfoot 1103 and the same router.
    But it worked with 2,4 Ghz Network when set to 54Mbs.
    When set to 5 Ghz or 130 Mbs or 300 Mbs it does'nt work.
    Really sad I have to say, since the WNDR3700 is no cheap router.
  9. Aikimox
    In that case you should contact Bigfoot Networks and see if they can offer a solution.
  10. Mr. Fox
    I have a NETGEAR WNDR3400 router and it is a little buggy. It's also not a cheap router. Hindsight is always 20/20. I never had any issues using Linksys routers and should have stuck with them when moving up to wireless-N technology.
    I have the Intel Ultimate-N 6300 wifi card. What (if any) performance advantages does the Killer 1103 offer over the Ultimate-N 6300?
Similar Threads - Bigfoot Killer Wireless
  1. low9
    2
    248
  2. etcetera
    1,007
