Bigfoot Killer Wireless-N 1103 compatability
Discussion in 'Alienware 18 and M18x' started by rawhide85, Jun 11, 2011.
  1. Aikimox
    Aikimox Weihenstephaner!
    We ship worldwide, shouldn't be a problem ;)
  2. MaynardLD50
    MaynardLD50 Notebook Consultant
    Did you not install the bigfoot manager? I'm going insane. I'm on my second Bigfoot driver, Dell has sent me 2 now, and I'm having the same issues. It disconnects from the internet, but says it's still connected. Hangs for about 10 - 20 seconds then kicks back on...Going nuts.
  3. Aikimox
    Did you completely remove Intel Wifi drivers first?
  4. MaynardLD50
    Definitely. Wipe it clean of any Intel drivers. So I redownloaded the .183 drivers and how the hell do you install these? I destroyed anything Bigfoot from my system, CCleaned, restarted, installed the .exe and now my WiFi won't work but in the Bigfoot network manager it says Wireless card is disabled. I'm seriously about to punch this card in the face.
    Luckily I found a .213 version I still had downloaded and it worked fine. Latency seems ok, definitely not a fan of Bigfoot though.
  5. Muzyczuk
    Muzyczuk Newbie
    Hey, i would like to buy one!
    It's possible to send with 2 stickers?
    Thanks.
    ps. contact me at
    teamflashhouse@hotmail.com
    Thanks.
  6. DanXbix
    DanXbix Notebook Deity
    Not sure if it's the right place to ask but when transferring larger files to server via wireless 450mbps connection, I get speeds of 75Mbps until file transfer gets halfway and then slows to 3mbps. Using a TPlink WirelessN router and teracopy. Server is running raid5 ext4 filesystem. also running official KillerN drivers.
  7. Aikimox
    Sure, you can have it with 2 stickers :) Email sent.
    I have a similar setup, but a slower router (216MBs max) and copying large files never drops below 150. What speeds do you get with smaller files?
    I think, the best option is to contact Bigfoot support directly. They have been pretty helpful so far.
  8. bahnzii
    bahnzii Notebook Consultant
    Aikimox, sent you a PM for pricing :)
  9. Aikimox
    Your order should ship tomorrow ;)
  10. sdruley
    sdruley Newbie
    I am new to this site so I might have posted this to the wrong place.
    I accidently uninstalled my Network Manager. Now I can't hook up to my wireless source point. Is there any way to get this back or do I have to restore to factory default?
