Bigfoot Killer Wireless-N 1103 compatability
Discussion in 'Alienware 18 and M18x' started by rawhide85, Jun 11, 2011.
  1. rawhide85
    rawhide85 Notebook Consultant
  2. GreaseMonkey90
    GreaseMonkey90 Notebook Evangelist
    yes its compatible. if you look up at the dell drivers, you can see that you are able to download it.
    but the question is.... where can you get the card? so far the card is only available when you purchase a clevo laptop.
  3. rawhide85
    You are correct. Perhaps some of our NBR "notebook retailer" friends may help, i.e. Aikimox, Malibal #2, Sager?
  4. Aikimox
    Aikimox Weihenstephaner!
    Yup, the card is orderable ;)
  5. GreaseMonkey90
    aikimox. i would to place an order :)
    how much is it anyways?
  6. lichensoul
    lichensoul Notebook Evangelist
    I would also like to order one of these. I have been really disapointed in the intel 6300.
  7. Aikimox
    We are in the process of updating the website. It will take a few days before you can order it online. Those in a rush can try ebay sellers.
  8. AirJordan
    AirJordan Notebook Evangelist
    So apparently it performs better than the N 6300 and is also cheaper. Is it easy to swap out the wireless card? If so, then I will leave it at the 6200 and just buy the Bigfoot and add it in.
  9. ichime
    ichime Notebook Elder
    Aren't those Bigfoot cards really Atheros chipsets? Not that it's a bad thing because I think Atheros is the better of the two (vs Intel). I'm waiting for the Atheros AR9462 which is a Dual band chip with Bluetooth 4.0 capabilites as well. I'd like to see something like that from BigFoot.
  10. Red Line
    Red Line Notebook Deity
    So if i order m18x with Intel® Advanced N 6200 a/g/n 2x2 MIMO as stock and upgrade to Bigfoot i'll still have Bluetooth 3.0, cause it's a seperate module? How to switch 2 antena adapter to 3 one? Where to get an extra cable?
