Better GPU fan
Discussion in 'Sager and Clevo' started by Danishblunt, Oct 9, 2018.
  1. kothletino
    kothletino Notebook Consultant
    The modified 8970 could reach a temperature of 86 degrees while playing. The laptop stood with an open lower service flap, on the notepal u3 with 3 fans that constantly blew air on copper radiators glued to the heatsink of the graphics card core, reducing the temperature to ~ 80 degrees. If I find a way to remove them gently, I will do it. At the moment, the lowest temperature for gpu with fan rpms forced to the max is 64 degrees. So yeah, nothing special.
    But p170 heatsink is not the same as p3xx one(i got both of them, the "better ones").
    Khenglish, valuable remark, I did not include it.
  2. Prostar Computer
    The adhesive on those copper heatsinks doesn't hold up to the temperatures the CPU and GPU tend to dish out. Keep an eye on them, as they may come loose and you don't want them making contact with the board.
  3. Danishblunt
    Danishblunt Guest
    The only difference is a metal plate connecting the vram heatsink with the 2 heatpipes from the GPU. Otherwise they are the same.
    A couple degrees, I'd say max 3-5c improvement. Fans are around ~80% according to Obsidians Fan control.
  4. kothletino
    Thank you for your advice. Copper heatsinks are attached to the graphics card heatsink with the Arctic Silver Thermal Adhesive, and not by black double-sided adhesive tape. ;)
    Unfortunately, what you write is not true. You can see the heatsink from p170EM v2 on the previous page, and this is what the p3xxSM looks like.
    FTW_260 and Prostar Computer like this.
  5. Prostar Computer
    In that case, you should be safe. :vbthumbsup:
  6. Danishblunt
    Danishblunt Guest
    Tell me the difference, since all I see is basicially the same heatsink.
    In term of thermal performance, they are pretty much identical. Aside from clevo trying to slightly improve on design which failed, there is no difference.
    Even tho the vram heatpipe is slightly longer it doesn't really change anything at all.
  7. kothletino
    Thanks to this, heatsink is more stable, and this plate also has a better transmitting heat than that the one from p710EM. I used both heatsinks in my clevo, the one from p3xx0sm had a few degrees lower temperatures. In addition, the heatsink installation from 3xx in the p1x0 series required modification of the service damper (cutting out).
    FTW_260 likes this.
  8. Khenglish
    Khenglish Notebook Deity
    You should get a much larger improvement if you can flip the fan upside down within the shroud. Then your fan will spin in the direction the fan shroud and heatsink were designed for.
    t6nn_k likes this.
  9. t6nn_k
    t6nn_k Notebook Consultant
    Or flip the whole fan upside down like seen in new Clevo P775TM1.
