Better GPU fan
Discussion in 'Sager and Clevo' started by Danishblunt, Oct 9, 2018.
  1. Danishblunt
    Danishblunt Guest
    yeah it's with afterburner.
  2. Danishblunt
    Danishblunt Guest
    Was forced to build my own fan.
    bennyg and t6nn_k like this.
  3. t6nn_k
    t6nn_k Notebook Consultant
    What is the best replacement fan for GPU?
  4. Danishblunt
    Danishblunt Guest
    if I knew that I wouldn't have been forced to build my own :(
  5. Damin
    Damin Notebook Geek
    hey bro do you have the eurocom bios for that system with (Fn + ) ?
  6. Danishblunt
    Danishblunt Guest
  7. t6nn_k
    Could you explain more about that fan upgrade? I see different wires so new motor? Does it uses same voltage as stock?
    And almost double fan blades (17 to 29).
  8. Danishblunt
    Danishblunt Guest
    Yes it uses the same amount of voltage as the previous one does.
    As you noticed i switched out the motor and the blades to gain a better airflow.
  9. t6nn_k
    What laptop uses that fan where you got your parts?
  10. Danishblunt
    Danishblunt Guest
    It's a P870DM fan.
    I tested the temperature in gaming:
    The GPU is TDP unlocked to 100W and I streamed Witcher 3 to simulate a high load on the CPU.
