Beta BIOS - Possible Missing Keystroke Fix
Discussion in 'ASUS Gaming Notebook Forum' started by Gary Key, Dec 13, 2010.
  1. mite_jan
    mite_jan Notebook Deity
    lol you've got me excited :D
  2. skygunner27
    skygunner27 A Genuine Child of Zion
    That fix(hard press of the right touchpad button) is what has usually worked for me.
    I don't think Gary intends on addressing the touchpad specifically because it's hardware related. If he was he probably would have done it by now.
  3. mite_jan
    why hard press can it be done with a normal press of the right button?
  4. Jody
    Jody Notebook Deity
    I can't get mine to work correctly at all. It has completely flaked out. I touch it and the cursor jumps two inches to the right. I've tried bios 211 and 209. I've tried removing and reinstalling Synaptics 15.0.11 and 151.9.
    I'm stuck in one of those endless driver remove/add loops again and can't figure out what I did last time that finally worked. <sigh>
    EDIT: I turned off pinch zoom and chiral motion and it seems to behave a little better now.
  5. Morecoffee
    Morecoffee Notebook Evangelist
    The hard press is usually because I am mad at the time. I think just a normal press is all that is needed.
  6. PhnX
    PhnX Notebook Evangelist
    The more features you have enabled, the worse it'll behave. Tap-to-click seems to completely break mine.
  7. frosty5689
    frosty5689 Notebook Evangelist
    It was working perfectly for 3days, then it started going crazy again.
  8. Morecoffee
    I turn off all of the 2 finger scrolling and leave the Chiral scrolling on. I also turn off the horizontal scrolling and all of the touch zones.
  9. frosty5689
    Its kinda obvious that the Engineers at ASUS doesn't test this for more than 24hours before releasing. The problems re-occur often after 2-3days.
  10. Ruckus
    Ruckus Notebook Deity
    Amazes me you haven't figured out only a few have this problem and hundreds of thousands of people don't. Personally I think you all just need to RMA your notebooks and get the touchpad etc replaced instead of whining about bios updtates for over a year.
