Best way to make Vista Sidebar 100% transparent?
Discussion in 'Windows OS and Software' started by justinluck, Apr 5, 2008.
  1. justinluck
    justinluck Notebook Consultant
    Hey guys, I want to get rid of the shadow gradient on the Vista Sidebar. Ideally, I would like to completely transparent. What is the best way to go about this? Do I need to install a skin program? And if so, which is the best one? Thanks!
  2. AKAJohnDoe
    AKAJohnDoe Mime with Tourette's
    100% transparent would be invisible, right?
  3. McGrady
    McGrady Notebook Virtuoso
    I think he means that he doesn't want the outlines of the 'box' on sidebar. He just wants his widgets there.
  4. justinluck
    Oops, sorry about the confusion. I am talking about the Sidebar background. By default, it is transparent on the left and fades to black to right. I would like it transparent, so I see the gadgets in the Sidebar, but without the shadow effect in the background.
  5. Gintoki
    Gintoki Notebook Prophet
    As far as i know, you can't.
  6. Diablo
    Diablo Metalhead
    um...drag the gadgets off of the sidebar onto the desktop and close the sidebar, but not the gadgets.
  7. Pai
    Pai Notebook Evangelist
    Jackpot! Or you can right click on the sidebar and click "close sidebar", just be sure you don't mistakenly click "Exit" caz that exits the sidebar completely.
  8. justinluck
    Thanks guys! That works.
  9. McGrady
    oh yeah, i didnt think of that. i forgot about it actually. i remember i did that for app launcher, when i used vista sidebar, but now i dont use that. its sux. ;p
  10. Evan42
    Evan42 Notebook Guru
    what do you use in lieu?
    i use objectdoc to launch some programs, but what do you suggest for cpu and ram meter, stuff like that that I currently have on sidebar?
    I tried rainmeter, but i think I'm too dumb to use it. It's less user-friendly for non computer programmers than sidebar.
